Paint is like 14 Years already, clear coat peeling dy.....lol
is it easy to install abs ?
Nothing is impossible if your mechanic can do it, abs need pump with the built in module, brake fluid tubing,speed sensor teeth on the cv joint, and abs sensor on your knuckle, dont forget the electrical wiring for it, but it is considered hard job mine ori come with it, but not that worth it as increase quite some weight as the abs pump with module is abt 3-4 times the size of the modern car having today:stupid:
come lets repaint cars sama sama!!
must it use ovo3 abs or any abs would do? i mean the abs module,![]()
Not on original paint anymore? So, if you go for respray, that will be the 2nd respray?
Your car is on original paint or resprayed before?
Car bought second hand was resprayed then I did another round...lol
Something like that unless previous owners did more.....hahahaha
Oh, so you are using 4G91. Still, you got more valves and an extra cam compared to me, hahaha.
Your real name exposed, so it is sort of easy to identify you at fb. Perhaps you might know my name at fb too I guess.
Was on 4G91 last time, imho for daily drive torquey lower end are always a plus, you'll be sick of it when you always have to downshift to get power
4G91's top end are better though, stock 4G15 ran out of breath pretty early.
Not too sure which one is you, just guessing only hahah
Last time on 4G91, now on what engine?
4G15's top end is limited by its single cam.
I thought you already know which one is me, hahaha.
93 bro. actually just an extractor would helped it breath better i think. single cam can make power also bro hahha imho cam designs play a bigger role.
roughly only lah haha not too sure
A full exhaust piping mod should improve the top end you mean? Changing cam will shift the power band..
By the way, Happy Chinese New Year to you.![]()
Yeap, extractor and appropriate sized piping would definitely help it breath better. That's the con of having "strong top end" , you can't have both lol.
Happy new year to you too, cheers.![]()
Actually, do air filter upgrade even changes anything in low powered NA engines like 4G15? I'm quite skeptical about its effectiveness... Might as well stick with original filter?
Some say any upgrades to intake or exhaust must be accompanied together.
I think it does feel easier for the revs to climb, but extractor would make a bigger difference.
Yeah, it does go hand in hand hahah personally i would go for extractor for the first upgrade
Agree with you. Extractor mod first before air filter.
I actually tried before running without air filter for a short while. No noticeable improvements except the crazily loud induction sound.
Since you said your exhaust needs replacing, change the extractor also while you're at it![]()
Oddly for my car the pull is stronger without air filter lol probably my air filter suck balls
