#OGPIM
Now its confusing.by satria you mean proton & mitsubishi?
you can try my mech at Jalan Bukit Kemuning, Shah Alam if it's near your place. Waze Upwork Racing Workshop or Bengkel Kereta RF Auto Service.![]()
Satria & Mitsubishi?
For the rims, that's definitely a caliper problem. Just go do caliper/brake kit service. Not that expensive. Less than RM150 for both front wheels. The brake kit comes in a set of 2.
Boleh broCheck first what is wrong. If piston jam then need the kit for service. If pin jam just need to clean and grease back....![]()
YO Senpai...
Any suggestion for Bucket Seat?
Got some mates told me that China does produced some reliable seats.
YO Senpai...
China brands i dont mind.brand new or used?
I checked a few used unit. Its ciplak.How about getting from halfcut? Used but at least is from a reputable brand.
Used half cut i also dont mind...
Recaro from Evo 3? But that seems to be quite expensive...
Or those Recaro SR3 or SR4 from Honda Type R cars.
Good is expensive loh! Buy ciplak ones sure will regret later......![]()
What engine? Sorry....I don know lah
Hi Senpai
I have one nerdy technical question:
The Throttle Body, whats the ideal tweaking?
I tweaked it to RPM1100( when air con is on ) ,its about RPM2100( when air con is off ).
Does it effect the performance?
I noticed that its quite noisy & the "checked engine signal " popped up few times?
Since he mentioned at the start of the thread, Satria 1.6 stock, means should be 4G92P.
Hi Senpai
Then the FICD is not working......![]()
Satria 4G92Since he mentioned at the start of the thread, Satria 1.6 stock, means should be 4G92P.
Tool List:
Soldering Iron
Drill for mounting switch
Multimeter
Drill bits and solder
Part List:
1x 3.5mm Stereo...
