Im also using Wira. going to throw e3 inside. autofoam is where they put 1 kind material inside the hollow of chassis.. so it reduce chassis flex, noise, great handling n etc.
bro...if u do mounting change... my mechanic tell that have to pateri the new mouting n got many work. bro evo3 ENGINE still ok in half cut shop. Don judge the engine by its age. if u throw the evo3 engine, u can mod it n can feel the damn G.
Again its up to ur taste. Make sure u do a Monster Wira. later we can cucuk each other at highway...lol.... kip in tuch bro...
remember bro >>>> Make sure u do autofoam, chassis welding at engine bay n gearbox area n put all the damn Ultra Racing bars, n adjustable suspension, n brake system. Safety 1st, Handling 2nd, Powerrrrr 3rd.
Yea I heard chassis welding is illegal for otr cars too. Why not foam? It works.
.... and it was an absolute pain in the arse rewiring it.
I take it that the new wiring has to run from outside of the beam; likely under the carpet. Did you have to drill a new hole to insert it back into the beam?
well....got pro and cons. Foaming is better alternative.
If chassis welding illegal, full stop. Who know, accident then want to claim...![]()
Foam doesn't strengthen the chassis in a significant manner
dont even bother with welding...
foaming, make sure its done properly and it's alright i guess..... keep in mind, it's an irreversible process with its fair share of pros and cons.
pro: strong (played with excess foam before, for the most part i guess it does the job
con: in an accident, the chassis might not give way as expected by the manufacturer. The car feels harsher, messy and not easy to clean up. Also, makr sure you know your chassis well, any wiring/drainage might get buried or blocked. In some cars, the door switch is located pretty low down, in my case, this cable got buried... its fine while it works but one fine day it snapped.... and it was an absolute pain in the arse rewiring it.
Oh as a idiot myself, I have to tell you if you choose to foam - go with Autofoam the original foam. Anything else is a waste of time and money (even though cheaper).
Just as an FYI though, some insurance companies will not pay if your car is foamed too cuz it's impossible to fix if banged up.
Seam welding is just strengthening existing stock welding points or weakened ori welds. Or just sell your car and buy an original Satria R3 car which comes pre-welded by the R3 boffins. Or the Satria Neo Clubsport which is welded and roll-caged by R3 and both cars are completely road legal.
Thanks. One of my door switches no longer working. Was wondering how I should go about fixing it
..Defnitely, but it does help to a certain extent i guess... My friend's car has been rear ended badly, after foaming it does strengthen the chassis quite abit. But again that's an old chassis that has been rear ended.
