ya loh....i need to pay extra. Which not worth the car value. But i need to drive....roadtax.![]()
With NCD, not that expensive right? Think mine is about 374
Bro, what spring rates are you using?Ftuned, for our local made coilover. I got not comment. Is good. Pricing acceptable.
I using it also. No regret.
6k/4kBro, what spring rates are you using?
Mine are 10/8. Goes around corners well but you need to take road humps with care. Contemplating changing to lower rates. Too bad you stay so far. Cannot test to see how it feels6k/4k
i stay in penang..
The last time it got stolen, it was in a gated community with guardhouses at 2 entrances to the taman. That didn't seem to bother the thiefs.
Good thing is those people aren't pros. They jammed a screwdriver into the ignition key to start the car. They might have started the car but in doing so, they also jammed the starter. They drove off with the starter running. Didnt get far. So they abandoned the car.
Your's should be much nicer than mine. Mine is an old banger with peeling paintwork, heavily accesorised with rust spots. From the outside, it looks like a typical piece of junk :embarassed:Is your car heavily modded? Or yours is a C99 Wira 1.8? Mine is the same colour as yours but not C99.
I should get custom sticker for it. Boldly emblazoned on the sides saying .. DEATH TRAP!![]()
I don't think mine is anything better. Year 1999 car. Currently rust spots are appearing on both front doors and rear bonnet. Will probably replace the rear bonnet but not sure what to do with the doors.
Respray definitely needed already. Can see a bit of faded paint marks on top of the car. Like these.
DIY bump is the worst...old car, this bits memang biasa macam ni... when repaint, can do these up as well...
Weatherstrip memang biasa. Respray will fix it. Dont lose the weatherstrip though. Those things not cheap.I don't think mine is anything better. Year 1999 car. Currently rust spots are appearing on both front doors and rear bonnet. Will probably replace the rear bonnet but not sure what to do with the doors.
Forgot if the rear are monotubes. Should be since I took the track/touge specs.10/8 sure bone cracking,yours should be all four inverted monotube ?
Ha Ha .. I turn this thread into a road hump bragging contest. I think hard to find another taman with more road humps than my place. My friends used to called my taman ... Shaolin 18 bronzemen. That's how many it takes to get to my apartmentMy taman only have 8 diy bump just to reach house.DIY bump is the worst...
renesis, the rain gutter strips can repaint or replace. No problem....body and roof no chicken pox , no worry.
Show us a picture of the doors. If just mere rust spots without holes, apply rust converter. In my experience, holes on doors not worth salvaging. Better to get new door skins or replacement doors from chop shop. I replaced all of mine about 10 years ago. Japanese doors much better. No sign of rust so far
Didn't ask which model those doors came from but it's been more than 10 years already and I dont see signs of rust on the door surface.What do you mean by new door skin? I'm not familiar with this.
The glue method in sealing the roof is used in Lancer as well.
One thing Wira parts hell of a lot, everything can change......lol
Door skin is just the outer layer which kena rust. They peel off the metal sheet and replace with new, keeping the old frame
Yup. Skins didnt appeal to me too. That's why I change the entire door.This door skin method doesn't sound very reliable to me. I'll show a picture of how the rust is on my door.
Should be Lancer or Libero (Lancer Wagon). Otherwise, no other door can fit Wira properly.
The rust spots on your car are all aligned in a straight line. Isn't the glue line located further below there? Wondering how come you have rust developing there. Think you need to change the whole door before you go for respray. In my case, I got fed up because someone poked his finger on my rust spot and the finger went straight through.![]()
actually the kulit replacement seems to work.... few friends who owned wiras before did that, seemed fine after....
roof rust, if don well, then really throughly coated, should last a while... as faidik said 50/50 chance it kam back...
my mechanic also said, it will either come ack very quickly, or be gone for a loong time if not for good..
