SATRIA 1.6 - Seeking advices for TUNING & UPGRADES
check isc. I think u playing with the bypass BISS screw to adjust rpm. if 92 have one.
Don play with biss screw. Is for fine tuned, not to set rpm.:listen:
Isn't the BISS screw is meant to adjust the idling? You set the idle using the BISS screw and adjust butterly via the throttle adjustment screw behind. ISC cannot adjust right? If rosak need to change the whole thing which gonna cost u around rm300 minimum for brand new ISC unit. :hmmmm:
rpm adjust by isc. Automatically.
If over adjust biss screw, isc will counter it until jammed. Because ECU wont know isc in which position.
need scan tools. to set it back.
F1 idling bro. :adore:
Your car got FICD or not? If not, your ISC Valve rosak dy.
I don't think he got FICD :hmmmm:
Actually called differently. ISC - Idle speed control actuator, FICD - Fast Idle Control Device, IAC - Idle Air Control valve.....lol:rofl:
Hi Senpai
Whats your view of having a muffler hidden behind the bumper?
Refer to the attached pic. I feel quite lofi & kinda like it.
