Rebore it to 2 litre to fit 4G63T pistons.
A lot to bore. 81.5 to 85.....fuh!
Identical block, like 91 92 93,need rebore and put in all the internal from 4g63,redo oil squiters etc.. Much more job
The 6A13TT project is just for the sake of uniqueness like dare to be different. Perhaps for the V6 engine sound also. If is about power, 4G63T is the much easier way.
I start to think that except Proton or maybe Perodua other kinds of ridiculous swap involving mounting modification can be passed somehow. Look at those older BMW or maybe Mercedes. People swapping in RB or JZ engines into them and yet still able to endorse. Actually, can these BMW or Mercedes chassis able to withstand the power of these powerful 6 cylinder engines?
Maybe 4G63T CK type is not allowed because of the 2 litre thing. Then how bout those CK 4G93T or 4G92 MIVEC. I know the mounts need to be fabricated but isn't that the same for other cars with engine transplant from different makes? Again, probably because they are Proton.
hehe next time i show you something very interesting....hehehe
Its sad to see old gen bmw like e36 plonk in jdm engine. Having powerful NA engine is fun and for now, halfcut for e36 is quite cheap compare to jdm. I thought there is thread in zth v8 iinm plonk in e34 kut. not sure.
Im not sure, but for conti car there is no 25% rule for engine swapping? is it true?
I wonder what is it![]()
or his modded 2jz, too powerful until car not moving.
can keep 1st and 2nd gear in store.
must spend money d. launch control, electronics control....etc
ur friends plan to put 2jz in future....when tired of sr20det
my fren is take 1jz from bmw and put into crown.
if 318i don't think can plonk in 2JZ cos JPJ only factor in 25% increase of engine CC,
therefore max he can go is 1JZ if he is lucky to get in endorsed.
Show me via internet or in real when I visit PJ?
Soon, NA charm will be popular again due to most performance cars going for turbo. The NA sound, high revs and response will make them stand out more than forced induction. My friend who owns a E36 plans to put in a SR20DET into his car. He wants to try that first until he is bored, then only he will go for 2JZ-GTE. His E36 is a 318i. I wonder can the chassis take the power from a heavily modded 2JZ-GTE or not.
haha nolah internet je, somebody doing something abit interesting...
actually - it's more of a question of "why not?"
Proton non-C99 chassis is weaker but all you need is money and send the car to R3 for the boffins to do up the car per your requirement and legalize it. Satria R3 was spot welded, Neo Clubsport had rollcage, all legal.
The Putra I was harping on about had slightly more than 300whp and went on track every other weekend. Sepang once had his bumper fall off supposedly because of his canards and it was producing too much front downforce it tore the plastic joints right off. After about half a year, the owner noticed a lot of strange squeeky noises and after some checking discovered cracks (very visible) along the front left absorber mounter area near the engine mounting and the front radiator chassis area there. Cracks. I never thought it'd be possible crack a chassis especially the reinforced area around the suspension mount.
Even after spot welding, will the chassis be strong enough? I remember one of your old quotes about a Putra with chassis cracks.
Your quote back then.
I transplanted a B16a engine from JDM EK4 into my local model Civic EJ7 a few years back. From what I've read, for EK generation Civic the chassis production method and the material were the same. I forgot to bookmark the website, it's in Japanese, so I used the google translate function. However, for EK9 Type R, the thickness of some parts of the chassis are different. Seam weld were also used in certain section to increase body rigidity.
The engine that I transplanted has only about 60bhp more than the original one, and because the chassis is virtually identical to EK4 Civic, there should be no problem. But just to be sure, I installed some 3-point front strut brace, rear & fender braces, and some stiff rings (like those Spoon Rigid Collars) beneath.![]()
my ex-EF3 with B16A had a full chassis strengthening via spot welding done to it by the ex-owner. he ran the car extremely aggressively with super stiff suspension for about 2 years before selling it to me.
and when i owned it, i had even stiffer suspension in it. had almost nightly drag races etc.
when compared to my friend's original EF9, can feel that the chassis is stiffer on my car. even when half parking on a slope, opening and closing the door had no issue with mine as compared to my friend's...the issue i mean is the lock thingy and the hook not aligned when parked on a slope.
as for long lasting, hard to say as i also only owned that car for 2 years.. but basically no funny squeaks etc during ownership and aggressive use and ownership.
