No need to go 16' la. Even if you buy lightweight 16' which would not slow you down, the tires will become a bit thin already (195/50/16 or even worse, 205/45/16) hence not comfortable anymore.
I was actually thinking about going for the stock Wira SE size which is 205/45/16 if I am using lightweight wheels. But is that really that uncomfortable if lets say compared to something low profile like 195/50/15?
That is why need to see priorities. Like Asy2 215/45R17 last time RM460, HPY RM360, if okay with 80% of Asy2 traction and handling, it cost 80% of Asy2 also....lol
Like Land Golden now transfer to my NA Hyundai, good enough and cost RM220 only....lol![]()
With the introduction of Asy3, this means Asy2 will be phased out?
I've used once before 195/50/15 on my CB5 like over 15 yrs ago when I was still much younger obviously and even then I didn't really like it much. Hence once finished I changed to 195/55/15, felt way much better without any much compromise on handling too (at least for my amateur slow driving). If you want thinner, like bro Vr2 suggested go with 205/50/15, that's the minimum I'd personally use as the sidewall height is still still above 10cm (10.2cm) compared to 195/50 at 9.8cm while 205/45 is only wafer thin 9.2cm.
