Perdana V6 Community Forum *
Hi all
Whn i drove my pv6 in evening like 1pm with aircond switch on....d cars timing seems to go ups & down
Wht went wrong with it?....
Whn I drive in the m.nin....its ok....stil puzzle over ths issue...
Can pv6 ecu be reprogrammed or remap?....
I ask a programmer guy in FB,he mention pv6 ecu not supported?....Is this mean that v hv2 get anade programmed ecu to tap with the genuine ecu?
Hi all
try using Toyota FICD
not sure on the lifespan, but a used halfcut unit will costs between RM50-60
I m driving a 17 yrs old PV6.....
Is it advisible to use lighter grade engine oil like 5w/30,10w/30 or 15w/30?.....
Will these grades be too light for this engine?
Does the engine consume engine oil at the moment. Using 30 weight oil is not a problem and it all depends on your engine. For example my VR runs on hydraulic lifters and tried using 5w30 once. On cold start is nice, but once warmed up the lifters becomes very noisy. Using 5w40 is much more quiet so I switch back to 40 weight.... :driver:
Bought used Toyota Denso FICD....see if it helps on my "retarded " timing
Has anyone used Liqui Moly 5w/40....is the oil OK?,...
Thank you guys for all the advise and sharing
