GuyInPersona
I am using HWL ST1 adjustable (oren one) in my persona. The spring rate on the front is 8k and rear is 4k. However my doubt is on the damper settings. Based on my research, some say damper setting depends on spring rate while some others say set it to full hard or soft and tune from there based on driving style. But my question is :
1) can this damper setting helps handle understeer/oversteer ? If yes then which one need to be harden or soften for both situation ?
2) can this damper setting help reduce body roll ? if yes then which setting need to be harden ? is it the rear ?
Not so familiar with adjustables yet but wanna learn a little :stupido2::stupido2:
