didnt check what is the model...
either rhp or sport a1...![]()
What tyre size? If 50 or 55 series should be Sports A1, if 60 series then is RHP
No wonder their tire price oso like Michelin...Last time got article at Paultan abt their SUV tire...if i recall correctly their price for AT tire can get MT tire from other brand.
175/65-14 if i remember it correctly.... stock myvi tyre size
Viking bought over by Continental and they market them as the economy model. I think locally got 2 models only City Tech and Pro Tech. City Tech smaller sizes higher aspect ratio. Pro Tech lower aspect ratio, bigger sizes.....
I really want to use viking tyre at first i'm so curious cos i dont even know the brand untill
i found this feedback and makes me want to give a try to use viking... i hope viking is better than my current tyre brand... i'm doing a research, most of it said that viking have a good quality and suitable with all seasons in Malaysia
City Tech and Pro Tech hv same function and performance?? Which model is better for my Myvi, tyre size is 175/65R14 82S
Then is RHP model dy
Well, my Viking actually did better than my Good Year Duraplus. Good Year is a famous and larger brand but the entry level Duraplus fares worse than Viking City Tech.
Here is a picture of my Viking tyre.
I think for your tyre size have City Tech only. Pro Tech comes in larger tyre sizes.
City Tech more for durability, Pro Tech have better handling and performance
Having said that, if you are changing 4 tyres you should consider 185/60R14 size for your Myvi. Wider 185 size means contact surface wider by 10mm over 175. 60 series aspect ratio makes your sidewall firmer than the 65 series that you are having now. Firmer for better handling but not too firm to give your a harsh ride. If use 50 series then the ride will be harsh....![]()
That depends on how one drives oso.For sure it wont last as long as Michelin XM2 or Bridgestone EP200 but it justify the price tag.
Just asking! What's the speed rating for this Atr2 tyres? Thanks!
Depending on the size, either V or W
Fitted 225/45/17 and 245/40/17! Quite precise this tyre in direction change! Overall the noise level is acceptable but can be loud on a rough patch of road! Wet handling is good , maybe it's a new tyre! Took some sharp corners and surprised me that a budget tyre handle so well! No oversteer feeling! Now it made me think that my old csc5 was overatted!![]()
Naah drive it hard enough and the difference will be much more pronounced! CSC5 is surely way much better.
:hmmmm:
