Tire Price list Zth
tried 2nd set half cut, tyre did lock..without it, lock abit later...so if it rains/wet road i'll drive below 100...and no tailgating if theres right lane quite a few cars ahead...diff story for lane hogger.:biggrin:
its for my wife car,so mid range should be fine.. hahaha...ecopia ep300 or v2 concept 2 better?
yea...hahaha...but gyfa3 above 400...out of budget unless i got promoted..hahaha..ps3 will do :driver:
I'm of the opinion to always buy the best tire one can afford. Therefore if you can afford better performance tires, say the V12 Evo2 (which is still relatively cheap), why settle for the lower V2 Concept 2? Think about it, even if your wife does not drive fast, but there might be some instances whereby she needs to drive in heavy rain, or do emergency braking or accident avoidance maneuvering. So in those cases, would you rather equip her with the better performance/grip tires or just settle with those low end cheaper ones?? Remember also that your wife probably would not be as skillful as you, so in those situations shouldn't you equip her with even better than or at least similar with what you actually use yourself?? Choose wisely bro!
Listening to the soundtrack of Titanic.
You slow, I slow.
You brake, I brake.
You stop.
I overtake and try to put as much distance as I can from non-ABS car. :biggrin:
In the wet you can do that, but actually in the dry I find non ABS brakes better.....lol:biggrin:
duly noted.
Currently fitted with v2 concept 2. this was the best tyre i could find promptly at small tyre shop last time. previously using ecopia 200, this tyre abit silent than the current one. Most probably next tyre will focus on comfort/silent, not sure if there is any for 15"donut
duly noted.
Can refer to this latest test in the US. The V12 Evo 2 came out as the most silent with very respectable performance even beating F1A3 and it's available in 15' too.
http://www.tyrereviews.co.uk/Article/2017-Car-and-Driver-UHP-Tyre-Test.htm
Best tyre for wet roads: Continental ExtremeContact Sport
I have them on now and approve this, I was very surprised how much grip it has on the wet and how confident it is taking turns.
Oh this is new tire, so you just bought them? How much, where, and what sizes?
looks promising and fit the criteria...hahaha..v12 evo2 really has it all ya..gonna survey the price later..
so confuse with continental..similar name on all range..hahaha :confused:
rode once on subie with pzero...damn it grips...same tier with extremecontact?
Shit, yea I just looked it up hahaha.
Well yes, very, plus my coilover feels like driving on rails tho hahaha
Me I cannot stand too thin tires like that. Old guy like me needs some comfort so I'm willing to sacrifice some handling/grip for a bit more comfort. :biggrin: Even my 245/40 now already feels just a tad harsh already even though still acceptable, but I would not go thinner anymore than this (sidewall height 9.8cm which is below my normal borderline limit of 10cm). Next change I might change to 235/45 + 265/40 (about 10.6cm sidewall) if possible, or at least maybe 225/45 + 255/40 (10.2 cm sidewall). Before this I use 17' rims with 11cm sidewall height (225/50 + 245/45) and it's just nice and comfy enough while still providing me decent handling.
Well it doesn't have it all, it still has some weaknesses particularly in the wet based on those reviews but considering the price and what it was compared against, then it seems a very good value for money.
Continental actually use similar naming convention for their tires BUT the confusing part is that sometimes the names do not really reflect the relative performance of the tires. For example Max Contact 5, you'd think should be the Max performance category rivaling those like Michelin PSS but it's actually just a mid range tire below Sport Contact series, only comparable to Michelin Primacy! Then the Ultra Contact might misled as if it's UHP class but it's actually just comfort tire, only 1 level above their lowest Comfort Contact series. Then their max performance category is the Sport Contact series. Now this Extreme Contact should be Max category as well, maybe same with CSC6 but for sizes below 19'.
I know right, I am hating the ride quality. Pretty jarring tbh considering my house is going thru some pretty heavy construction work to make way for the new duke, that’s why I’ve been complaining on the other thread. :rofl: But when the road is smooth, raining or not, it grips so well in corners. Though I still get occasional “DSC flashing” in the rain when I need power ahahaha.
Some might feel the tyre is too much for everyday use but if safety comes first, nothing is ever too much.
Note though such firm thin profile might actually be more dangerous in the wet and on unsmooth surfaces. In the wet, coz it's too firm, it's less compliant to absorb and grip and therefore might skid sooner. In unsmooth surfaces, it also might have more tendency to skip and hop instead of absorbing and gripping, hence also might skid sooner. Such thin profile tires only works very well if on very smooth surfaces (which is not guaranteed on public roads) and maybe on modern cars with sophisticated active suspension technology.
This is a good article comparing different profile tires on the same car. Conclusion is, going too big/thin profile actually is not always the best.
http://www.tyrereviews.co.uk/Article/The-differences-between-17-18-and-19-inch-tyres.htm
Noted on that, thanks for the useful info will read them at home later. :driver:
I just checked again, its actually 275/35/18 my bad!
Hmm 275/35 still not so bad then but already pretty thin too (only 9.6cm sidewall height). Generally I would guess just a bit harsher than mine now on 245/40 (9.8cm sidewall) but maybe yours feels harder coz the Extreme Contact may have firmer construction than my F1.
I'm no tyre expert but my front are 245/45 and the other time when I went to tai soon for balancing, the guy told me that it's oversized. However it's still under BMW recommended sizes for 18s.
But to matters worse their new MC6 are now classed as UHP.....:smokin:
any good recommendation for tyres that range around RM300++
prefer comfort and quiet.
currently on RE002, DOM in 2014, need to change if i not wrong?
size 225/45/17 x 02, or 225/50/17 but need to change 4 in total.. :sleep:
Yes, if your rear is 275/35/18, then your front should be 245/40/18. 245/45 is too thick so overall diameter with 18' is too big. I use 245/45 before but on 17'. How wide are your rims? If still max 8.5/9.5jj then next change can use 225/45/18 and 255/40/18, cheaper and more comfortable coz thicker profiles. Alternatively if can still fit, 235/45/18 and 265/40/18 are even better.
You're using 9jj wide rims right? If so, should not use 225, need at least 245, so best to use 245/45/17. if your rims are only 8-8.5jj wide then use 235/45. I would suggest the Hankook V12 Evo2 or S1 Evo2 coz they're value for money.
