FTO MIVEC not kicking...I am mechanic but could solve...HELP...
Hi Guys
I have swapped a 6a12 V6 mivec into my Mitsubishi Lancer. The Mivec has been kicking in great for a while now but recently my Mivec has not been kicking in most of the time. Sometimes it does in 1st gear but then cuts in 2nd gear. Sometimes it just does not activate at all. I recently changed my alternator from a 4 pin to a 2 pin. I Serviced the car and changed the oil filter and the oil and put 5W30 oil in the engine.
Any advice out there?
Hi Guys
am assuming you are testing the car AFTER its warmed up?
generally speaking, theres a few key items you that mivec relies on (or sort of checks for) before it can kick in
-temps, engine needs to be warmed up, will not kick if its cold
-voltage
-oil pressure
i believe those are some of the easier things to check.
if all fails, you got to start poking around the solonoids and ecu..
**oh yea... you can also pull some codes... that might tell you exactly what the issue is
