dun hijack ppl post la.. so finally did he buy the evo7? i boring mau scroll read long long granmama story
You are the type go watch movie skip right to the end....
sorry to hear that bro. Turbo manifold leak due to crack or just at the gasket?
Wastegate diaphragm how it leak? Also intake manifold how it leak? :hmmmm:
You are the type go watch movie skip right to the end....![]()
Guys,
Let's say hypothetically I want to buy an Evo 7, based on the ad below is this a good buy?
If not why not?
If yes why so?
http://www.mudah.my/2001+Mitsubishi+Evo+7+mr+2+0+M+-56418543.htm
Didn't know u wanted an Evo hahahaha
A guy called Cokan is checking for me now. The intake was leaking originally (see photo) and that was because some overzealous ass overtightened and the thread is gone.
The wastegate is a fake Turbosmart. The eboost controller cannot manipulate the boost levels. The exhaust manifold leak was because of shitty material. It glowed red during dyno and the unsupported weight of the turbo bent something and now it's leaking there. Getting a proper support bracket done and repairing the manifold. No more budget to change to a new one.
Hello. No did not buy the Evo7.
So true. Quite often the best parts of a good story is at the beginning & middle.Don't always look at ending only.......lol![]()
so leaking at intake manifold is just the threads? Can just drill and rethread one size up and put another fitting in gua. Wastegate replace with original wastegate. Manifold normal to glow red, and i don't think it's bent, probably a crack somewhere? You can hear the exhaust leak? How you managed to identify the leak? And yeah it's better to have a brace. Mine also have a brace made. Just weld the crack on the manifold and you should be good to go
the intake manifold is one thing - the other thing is the aftermarket manifold is leaking elsewhere too. Need to take whole thing out to check for cracks.
Wastegate being replaced.
Exhaust is VERY loud and very apparent that there's a leak. And yeah looking to just weld. The manifold is extremely restrictive though. Which is one possibility the EGT was running so hot. AFR and Ign timing is within normal parameters
Should come in more often. Thread title also inferred something similar.![]()
Lolol, was reading the nightstalker thread and see some active threads so just join in kacau a bit. but really didn't know Izso wanted an Evo, how different life would be.
The world would've spun the other direction
Wasn't your waste gate changed earlier?
Why you say the manifold is very restrictive? The collector not good? And why you say the EGT very hot? You got an EGT gauge bro?
There's no 'normal' parameters for ign timing. It could look advanced, but different engine different timing requirements. Only on the dyno you will know whether it is advanced or retard relative to the MBT timing.
The spring. Not the WG
Evo was always the first target. 3, 7, 9 and 10. But after speaking to owners, friends and getting opinions I opted not to be a dumbass. But apparently my latest choice was equally dumbass. Sigh.
Manifolds glowing red is a pretty good indicator imho. And a leak happening after a few red glowing runs is a pretty good indicator of hot EGT no?
No there is a certain range right. 60 deg for ign timing is not normal.
Why la. Is me owning an Evo such a far out idea?
That also includes those insisting on buying non "standard" cars lol...We're all financial dumbasses for even thinking about modifying cars in the first place![]()
What about the 7 & 9? Their diff is it?
