Basic Performance upgrade
hmm... fueling high? But it was stock ECU mapping and stock fuel pump back then. Which means it was just like any standard Airtrek from the factory.
I remembered once my the boost controller had some issues (clogging), it dropped down to 0.6 bar. Then I was accelerating with 0.6 bar and suddenly the boost came back to 1.2 bar during full throttle, there was a moment like it was injecting NOS. A sudden push back to the seat with strong g-force. Therefore I was able to tell the difference between 0.6 and 1.2, which was BIG!
Since then, I've been fantasying to buy a e-boost controller with scramble boost function. Hahaha...
---------- Post added at 09:51 AM ---------- 6 hour anti-bump limit - Previous post was at 09:50 AM ----------
Misfiring at high revs maybe because of your plugs are due for change.
Yup, when the boost went over 0.6 to 1 the pull was totally different.....hahahahha:biggrin::adore:
As far as I know, Standard fueling for turbo is already slightly higher.
The misfiring more of jerk, like a moment, current was cut. Could be due to over boost. After I got the vacuum hose replaced no more such issues....:smokin:
So, did the upgrade you hv listed improved the performance of your car?
will feel the Boost more power.
---------- Post added at 03:42 PM ---------- 6 hour anti-bump limit - Previous post was at 03:40 PM ----------
From the list the engine should be smoother, but number 5 looks interesting. If he has set the boost higher definitely much more power....:driver:
i set between on 1 - 1.1 bar.
Get a MBC installed and raise your boost la... :) hehehe..
Soon soon.......:biggrin:
---------- Post added at 03:57 PM ---------- 6 hour anti-bump limit - Previous post was at 03:56 PM ----------
1.1 boost very good already....
You guys still have your airtreks? I know the last reply was in 2014. Wondering if these discussions are still on
i sold mine last year, and been driving it for the past 7 years.. but still excited to talk about it. lot about airtrek i 've learnt, always felt like sharing it.
Sold mine in 2016. Missed it sometimes especially the turbo whinning sound and blow off valve. It was a wonderful car...
