I did a bit of look up on the internet. They say it will sacrifice the torque in the lower range, true?with 10k budget, you can port the head as well.
"The slight expansion of the inlet and outlet ports will slightly change the way in which your engine creates power however; torque will be sacrificed lower in the rev range due to the decrease in fluid velocity due to the new expansion of the port, but power gains will be had high in the rev range as a larger volumetric flow rate of air and fuel can makes its way into the cylinders."
Anyone know where can I get the clips from?? I search a few spare part shop in PJ area, they don't have it...
