hi..im new here...wat other mods tat i can do for my little monster to make a good hp and get solid power and torque...and wat i have done is,over bore piston using myvi piston,lighten crank shaft and fly weel...then port and polish head,hight cams 262 jasma...twin plate clutch..so called the clutch loceng...hehe...rim 15" exhaust hks super silent wit 1.5 inc pipe..open pots avs filter...tested on dyno,im getting 135hp, engine sup up to 1.4cc...
View attachment 572370 hi..im new here...wat other mods tat i can do for my little monster to make a good hp and get solid power and torque...and wat i have done is,over bore piston using myvi piston,lighten crank shaft and fly weel...then port and polish head,hight cams 262 jasma...twin plate clutch..so called the clutch loceng...hehe...rim 15" exhaust hks super silent wit 1.5 inc pipe..open pots avs filter...tested on dyno,im getting 135hp, engine sup up to 1.4cc...
Chassis can take it ah?plonk in 1.3 yrv turbo...
or buy y1.5 alza and do forged internal for turbo
That is the problem with modding, once used to current modded power, will need more.....hahhahahha
with that body like milo tin better dont think man..plonk in 1.3 yrv turbo...
I have heard of many wira with 4G63T having their spot weld come apart. Will be similar case if the engine is too powerful for this case....lolwell...its up to owner if he decides he needs more power and torque over anything else...![]()
on 3rd Dec 2010 around 2~4pm(don't know the exactly time) at puncak jalil..
