Porsche 1999, Carrera 996 NA 3.6L Boxer auto.
City driving 8-9km/L and highway can get easily 13/14km/L
RON97 only. :P
No wonder bmw1jzparking. Got porjeh.
RON97 only. :P
The fuel efficiency of your flat 6 engine is amazing... the 996 is an absolute beauty, one of my favourite. My highway cruising is only about 7.5km/L and about 7 with a mix of city driving.Porsche 1999, Carrera 996 NA 3.6L Boxer auto.
RON97 only. :P
How on earth you getting worse than the Porsche mpg?The fuel efficiency of your flat 6 engine is amazing... the 996 is an absolute beauty, one of my favourite. My highway cruising is only about 7.5km/L and about 7 with a mix of city driving.
Yeah, a loaner car. I can't personally afford the roadtax. half year 1.9k is insanity.No wonder bmw1jzparking. Got porjeh.
Yeah, bcoz u fill Vpower thats why u pay more. I just use 95 and i drive like old man some more hehe. i also keep the speed below 120kmh coz beyond that, the ECO sign is off meaning not economical anymore.
previous owner said use 97 also no difference, but sometimes like once a month, he will fill full tank 97 so can clean the engine. i dont know to what extent this is true. anyone use mark x here experience increase in performance when using 97/Vpower maybe? imho, engine is not cleaner using 97 compared to 95, but in terms of performance, maybe a little difference. any opinion?
Wow...super good fuel economy for a 2.5L V6!
My recent trip from JB to Genting to KL and then back to JB, Total mileage was about 950km.... Refilled about 3 full tank, about RM600 cause i pump only Vpower racing/Ron100 where possible.![]()
Rich man indeed.
RON100 I honestly doubt your car would use to its fullest. Vpower Racing is just RON97 with extreme additives and stuff. Good for cleaning your pistons and all that good stuff. You pump it every 3-4 fills is more than enough. Stick with RON97 enough laWow...super good fuel economy for a 2.5L V6!
What SUV you driving again?The fuel economy of the 3.6 flat 6 is almost unbelievable at 8-9km/l for city and 13-14km/l... many 2.0l and above cars averages 8-10km/l, and performance cars easily get lower than the 8-10km/l. For the larger SUV, i heard it’s also quite common to have 7-8km/l. And yes, 7km/l on highest grade premium is painful
For my car, the lower FC could partially be attributed to older engine and probably suboptimal tuning. Planning on a major project soon.
Use RON97 la. There's seriously no real reason to use anything higher. Switch to VPR once in a while and you'll save a lot.Haha.. I’m not, it’s sucking me dry.
, the premium price for fuel is part of the price to pay for performance...
V Power Racing is minimum RON 97... actually why bother just pump RON 97. Petron Blaze 100 is different la, really RON 100.
From some google research, 11:1 is already regarded as high compression, recommended to use 97. cant wait to dry up my tank and fill up with 97. huhuThe Mark X engine has a high compression of 12:1. Typically for higher compression engines, it is recommended to run higher octane fuel to prevent engine knocking. However most family sedan (typically non-sport models) are able to accept Ron 95 as the ecu will retard the ignition timing when lower octane fuel is detected. Mark X's higher compression engine should be able to utilize and extract more power from the higher Ron 97 hence it should make a difference in terms of power but then it depends on how fast the ecu learn and adjust to make use of the better fuel.
For my car, i can't use lower octane fuel as my engine will be knocking if lower grade fuel is used. Even Ron 97 is a little bit risky once my turbo is boosting (compression goes up substantially during boost), i'd rather pay for the fuel more than getting my engine fail prematurely.
you can read up more on engine knocking here -> https://repairpal.com/engine-knocking
More on octane rating -> https://www.carthrottle.com/post/engineering-explained-high-vs-low-octane-petrol/
ok let me search for the handbook now...i think your car should be able to run on Ron 95, believe for most family sedan, the manufacturer would have tuned the car's ecu to adapt to lower octane fuel. Higher performance variants such as Swift Sport and Civic Type R will require at least Ron 97 as the car is tuned for that. To be safe, do check your car's handbook for manufacturer's recommendation.
cannot find anything so far. what i found is this. this is for 2004-2009 model. my model newer but still using the same engine (in fact slighly less hp than previous one), it mentioned there can use RON95. So, i guess, it should be alright to use RON95..ok let me search for the handbook now...
My VR also 6-7km/L only.....lolHow on earth you getting worse than the Porsche mpg?
. Couldn't find the parts for CS3A in the...
