Dear All,
I have a car with 1JZ VVTI engine having consistent battery die on me issue. Symptoms i've detected so far:
1.) Power windows auto mode not working, unless i rev the engine to 2000 rpm
2.) Power windows roll up too damn slow
3.) Idling seems very low and at the point of stalling, when the rev gets about 400 rpm, the battery light turned on
4.) Lights were dimming but it was fixed after i replaced with a new battery (2 weeks old)
The alternator was fixed a week after replacing with a new battery, by replacing the carbon brushes due to its age. The engine starts and runs fine, however the power windows are still working slow. Idling still pretty lousy, at 650 rpm at cold start, but runs fine after warmed up.
One fine day, the battery died on me again, but partly due to the car is in a garage under going cosmetic repairs, the repair guy accidentally left the car lights on overnight. The next day we jump started the car but i doubt the battery is properly charged.
So far our test results as below:
Battery voltage while engine is off: 11.8 v (mechanic commented it is low, as it should be in between 12.2 - 12.5)
Battery voltage after engine started with no accessories on (radio, lights, A/C): 13.5v (mechanic thought it looks ok)
Battery voltage with accessories on (radio, lights, A.C): 13.8v (mechanic said it looks ok)
Honestly i think the alternator still do not produce enough charge or i am just being paranoid.
What are the chances i need to replace the whole alternator unit ?
Thanks,
Ken
Thanks,
Ken
and how much will it be roughly :hmmmm:
