Airtrek Parts Enquiry
sanekit
Hi sifus. I've been planning to get an airtrek. Not soon enough, still sorting out my budget. I wanna know, how hard is it to find the parts for airtrek? especially the handling stuff (lower arms, bushes, brake pads etc.) without breaking a leg. the 4g63t engine parts i know still got stock MMC parts that doesnt cost a bomb.
also, how reliable is the gearbox, transfer case and all? i read online the gearbox is rated at 35kgm of torque. what's the common problem u guys while having the airtrek?
thanks sifus!
Isn't the airtrek older than your defunct Wira? I'd guess it'd be double more expensive than your Wira.
airtrek is slightly newer. ahahaha. wira is based on the lancer/evo1-3. airtrek is evo 7 crossover.
my option is either getting an airtrek or a suprima S.
buy buy buy...
more or less similar maintenance...
slightly more parts to wear n tear due to awd
slightly more fc...(trade off for power)
better comfort and luggage space
better street cred
parts since sharing with evo 456789...should be no problem
buy buy buy...
better street cred
Whats the km/l on this thing?
One is SUV, one is car loh, depends what you want. Airtrek got mechanic Ah Wah also....haha
buy buy buy...
better street cred
i know the parts sharing with evo. but if go spare part shop ask for evo sure the price will break my wallet. ahahaha. the OEM parts can still get or not? like specifically for CU2W.
the FC more or less is somewhat similar to me whacking my wira daily. but surely gonna be slightly more coz i will definitely whack it.
airtrek my mech can oso can fix. hehe. just wanna know the parts and maintenance whether gonna damage my wallet or not. ahaha
dude, just get airtrek instead of suprima.. why?
because it shares an evo parts more than u know. it shares "C" chasis as airtrek are Cu2w/Cu4w while evo are also Ce9a or CT9a bla bla bla.. Engine internal were taken from evo 5 (include piston, conrod, crank, balance shaft). the Invecs 2 tiptronic gearbox shares from a evo 7.5/lancer GT. the whole front/engine subframes can be swap to any evo from 4 to 9, frt absorber can use evo 789. rear absorber shares with lancer gt (tho Lgt absorber are like 2cm lower). ECU is tunable by ECU reflash. even Gearbox can be tune by some old timer tuner but will slightly shorten the durability. stock dyno is around 190ish on wheel. stock turbo is a TD04hl (the biggest td04 in the td04 lineup). evo swap parts/turbo is good for 250 to 300whp. it is advise to stick around 350whp and below to keep the gearbox happy (but it may depends on how healthy is the gearbox, the culprit is the tiny wave spring. change to evo 7.5 wave spring thicker and stronger).
i would love to help u on any airtrek info, im a proud owner of airtrek for 7 years.
wah. this is lots of tips and info. 7 years stronk, any recurring issues to your airtrek?
hard to say recurring, but there is some common issues.. such as crack stock turbo manifold (normally occur after 10+ years), stepper motor (Idling motor) kong, MAF sensor kong, stock radiator fan kong, EGR dirty need to be clean, crank sensor faulty (after very long years), gearbox wave spring broken.
thats about it.. the most common is that first 3.
Parts are still reachable and can also source new from an authorized supplier such as Bintang auto parts (the best airtrek evo supplier i could recommend). some parts can use from halfcut shop, some are better buy new.. so u have to be smart. or if u have unlimited budget, just get all new parts..
First 3 not only airtrek but on most 4G63T, even my VR change manifold twice already......lol
ahh. ok. first 3 are pretty common for 4g's. so i guess i can expect something similar as per my 4g93 wira. this thread is giving me more determination to get an airtrek. ahaha. hopefully can reach my target this year.
For repairs and parts, you can still get it. Just contact Ah Wah. Contact info available at pinned topics.
My previous Atr averages around 5.8 to 6.5km/L. On highways, I get around 7+. Not the most fuel efficiency car but hey, you get plenty of space and fun. When I got the car, I raised the stock boost from 0.6 bar to 1 bar and used it for like over 2 years. Everything was stock and I did not face a single problem.
Then I dump all possible Evo mods, TD05, cams, injectors, block, pnp, full exhaust, fuel pump, dyno-tune, bla bla bla. Upped the boost to 1.6 bar getting around 270whp. I manage to clock 5.9 secs from 0-100km/h. It was fun but trade off with some turbo lag.
However I sold it in 2016 because it was an old car with aging problems, my wife drives it and we cannot afford to keep having problems like stalling out of sudden, bad starter, bad ICV, bad MAF, jam calipers, weird noise during cold start and many more. Even though I kept replacing the bad parts, new problems keep coming up. Remember, the car is at least 15 years now.
If you use this as a weekend car for some fun, then go ahead. Suprima S is no way near. However if you plan to use it as daily cow cart, unless the condition is superb, else it will not be practical due to reliability issues.
index.php
index.php
ah dang. if i buy this, my wife is gonna be using it as daily. need to really do a thorough check before buying then. another reason why i ask if the parts are easy to source. as in the handling and brakes parts. those are definitely need to be in good condition to be daily driven.
I am not worry about availability of parts. Ah Wah has almost everything under the roof. Sometimes you just need to give him time to search. As long as you have time (allow downtime) and money to repair, this is not a problem.
For me, the worry was reliability. There was a few times the car stalled in the middle of a hot afternoon traffic jam. The starter just click but not cranking. My wife has been complaining so much, so much that I decided to part with my big potato and got a new boring car. The good thing is, the new boring car is double the efficiency and it's reliable. So I have not heard about complaints for 3 years now.
hmmm. need to really get my budget straight up purchase and do. will see how it goes. thanks for the tips bro.
