Hi Sifu all, normally what is the price of top overhauling an 4G13, and what is the price of just doing valve seal repalcement? which one recommended? Is top overhaul include piston ring? thanks in advance...
700 is pretty decent. Just make sure he changes everything like the timing belt (since it's coming off), water pump, hoses, as well as the gaskets and stuff. Don't reuse head-studs too - personally I feel you shouldn't.thanks for reply, yes i do have a sort of familiar mechanic that I always send my car to him. He quoted around Rm700 for top overhaul job. Guess it is still cheaper then ur mentioned price, thanks!
Do you think i should do a compression test too before doing anything?Yup, I believe the total price also depends what is changed and what is used back.....
You're doing a overhaul. No need la.Do you think i should do a compression test too before doing anything?
haha okie dokie...700 is pretty decent. Just make sure he changes everything like the timing belt (since it's coming off), water pump, hoses, as well as the gaskets and stuff. Don't reuse head-studs too - personally I feel you shouldn't.
Actually what reasons or what led you to do the top overhaul?Do you think i should do a compression test too before doing anything?
