I think he means the racer catYou have a wira?
quoting cat-man lahYou have a wira?
Dei....aiyoo damage done. Haha...I think he means the racer cat
Daily race from home to factory and back, best is night shift......hhahhahahhahamana ada....daily car not racing car....lol
Your BOV is leaking boost out all these while and by luck your revving dislodge whatever dirt which cause the leak?Dear All,
Just about 2 days ago, my legs are itchy and decided to rev the engine hard while stationary just to listen to its BOV sound. After a while, to my surprise, suddenly the engine transformed and the car just accelerate even crazier then before, the air intake suction noise is so sound and car just sprints everywhere.
Until today i still can't figure out why the sudden transformation. Any one can help to clarify?
Thanks,
Ken
Have you upgraded the cooling yet? Also how is the water recirculating for your block? There should be water going to the back of the engine. Without this the engine gets reaaaaaally hotWell i did change my BOV settings back to stock, after discovered that my current SSQV is non-recirculating BOV hence caused the engine to idle and revs shitty. Anywhere else i should look out for so that my engine performance is consistent.
Thanks,
Ken
He's not wrong. JZs run hot. I'd go get a low-temp thermostat though.All still using stock BMW cooling system, on normal driving, the stock temp gauge shows that its lesser than middle line, spirited driving will push the temp pass mid line a little and stays there. My mechanic told me the stock BMW temp gauge, middle line is somewhere 90 degrees. The stock 1jz thermostat is fully open at 95 degrees so that's why through spirited driving, the temp climbs a little and stays there.
What's your take for this ?
Thanks
Ken
My reply will be some sort like bro. gunnerzz, revving the engine could have dislodge something, carbon piece stuck somewhere or cleared your injectors. You can see most mechanic when tuning, normal revs the engine......lolDear All,
Just about 2 days ago, my legs were itchy and decided to rev the engine hard while stationary just to listen to its BOV sound. After a while, to my surprise, suddenly the engine transformed and the car just accelerate even crazier then before, the air intake suction noise is so soundly and car just sprints everywhere.
Thanks,
Ken
Gotta love the stealth look.Under cover is best, like my VR now look like junk......lolFunny enough the revving was done by me, my colleagues all came out to check what was i doing as it was 745 am in the morning. They thought i am driving stock standard 318ci all this whileGotta love the stealth look.
Thanks,
Ken
That sounds like the more normal voltage (13.4 - 14.4V) on idle. Did you uprate the fan?Just modified radiator spare tank with a customized aluminium one. Adds blink to the engine bay. Also added a 500amp battery cable from alternator all the way back to the battery in truck. This rose the car's voltage to about 13.4-5v at idle will A/C on. Is this figure good enough?
Thank,
Ken
yup normal, as long voltage maintain. I get this figure too with battery relocated to trunk.Just modified radiator spare tank with a customized aluminium one. Adds blink to the engine bay. Also added a 500amp battery cable from alternator all the way back to the battery in truck. This rose the car's voltage to about 13.4-5v at idle will A/C on. Is this figure good enough?
Thank,
Ken
Remember to put fuse ehh...lol
| hi i wanna sell my evo 9 manufacture year 2005 register year 2006 import baru ap baru stock standard accident free aluminum roof mivec turbo 6 speed regular service recaro leather seats cd... |
