if I make harder rear can solve thisfloat coz your front is high and hard compare to the rear. 4g15 engine not as heavy as waja or 1.6 wira engine. change back to wira front absorber.
What setup suspension u recommend for my wira 1.5 sedan. Like which type of absorber and sport springfloat coz your front is high and hard compare to the rear. 4g15 engine not as heavy as waja or 1.6 wira engine. change back to wira front absorber.
Not necessary. When too hard, in the straights on high speed, can be very unstable too, unless very flat road.......if I make harder rear can solve this
Because I heard and though change 1.6 absorber will better at highway, so I did this setup. Now at bad road is stiff(this one can be understand bcuz abs hard) but at highway was not feel stable alsoNot necessary. When too hard, in the straights on high speed, can be very unstable too, unless very flat road.......
you mean float is too general.Because I heard and though change 1.6 absorber will better at highway, so I did this setup. Now at bad road is stiff(this one can be understand bcuz abs hard) but at highway was not feel stable also
You need better suspension la. Wira SE spring is pretty short. If you pair it with a long stroke absorber it will not do a good job la that combo.driving at highway feeling like duno whether front or rear is lompat lompat.. like unbalance
Usually use which type of absorber with SE spring is better. I thinks I need to resetup my suspension again, but I want to go for absorber or sport spring 1st, should I convert back 1.5 absorber?You need better suspension la. Wira SE spring is pretty short. If you pair it with a long stroke absorber it will not do a good job la that combo.
I think you need to look at your suspension setup again... or just drive slower until you have the budget to redo it.
Now my budget is allow me to use second hand adjustable. Below is my finding at marketplace.
Brand: Redsuns
Spec: front 6k rear 4k spring rate, High Low Bodyshift
Is It suitable for wira, how about the riding review.
My advice is don't mix and match different brands front and back. If you use one brand in the front, use the same for the back.What I want is riding at highway without float, I mostly ride at highway. I didnt care for comfort at city or playing for hard corner. Maybe my old absorber bouncing or playing is not equal left and right shock.
Now I saw market have selling short stroke absorber, brand Proride performance. For your advise, it is suitable to pair together with SE spring or search for sport spring. I also notice that SE spring coil is more tebal.
That PRS shop is far from me, Im from penang.
One more things, last year I just change 80% bush for my car(lower arm front and rear, long and short tulang anjing, tailing bush, satay bush) only infront antil roll bar with body 2 bush(not satay bush) I didnt change. Im not sure after I change big absorber have “knok knok” while driving at uneven road. My spring didnt lapik with rubber also. Put rubber at spring is needed? because forman told me unnecessary.
how's the condition ? if you have suspension specialist to check then is ok.Now my budget is allow me to use second hand adjustable. Below is my finding at marketplace.
Brand: Redsuns
if you still finding, msg me. They will help to check the ur current suspension if you want. Anyway is after raya.
i busy with factory overhaul.
i Want to confirm , you from penang ? kakaka
Proride is pretty good btw.
Ahhh arlim. He is good for my experience. He used to be ftuned dealers too. Now more to HWL.Ya, I working at batu kawan. Last time i service my absorber at Arlim suspension at bandar perda.
You can take care yourself lah. So you still go to Arlim suspension ?Penang taikor pls take care me...hehe. still have many questions to ask. If I try and error all the things, it was very waste money
Kantoi!!
