Falken FK510
Why not just use 245/40/18? Much cheaper and common size, closer to the front 225/45/18 and better fit for 8.5j rims on your F30.
boss
https://tiresize.com/comparison/
225/45 R18 fronts
255/40 R18 rears
are identical in diameter
245/40 R18 will be 7mm less for the rear...
2 front 1 brand, 2 rear another brand is okay. I use many times like this when changing brands.
I check a few shops, Falken some at 800, 730 cheapest. One shop no Falken say PS4 810, that is why I let you know......lol
You got PM boss. I think rear got better traction is safer. They say new tyres go rear.
boss
225/45 R18 fronts
255/40 R18 rears
I know diameter wise it's slightly smaller but width is closer so less understeering tendency. Anyway 8.5j also better match fitment with 245. I'm also now using 225/45/18 & 245/40/18.
FR setup naturally oversteers right? I kinda like the way my car handles now.. a bit of throttle it will still oversteer..
boss
225/45 R18 fronts
255/40 R18 rears
Replied to you already. New tyres rear, yours RWD even better, but yours staggered so cannot change......lol
So far so good. Wear still ok. Did a few braking, stops with plenty of room left. Wet also good so far, I only have experience with PS3 and not the PS4, FK510 is definitely just as composed as PS3 in the wet, I have confident and feel safe with it.
Should be the 3rd Falken model quite highly recommended. Those days was the ST115 model, then the Ziex ZE-912, but this model later failed. Now the FK510 seems to be making a comeback for Falken
Isn't there a ZE-914 already? Yes 912 was quite bad, my friend one was having issue back then.
Well no more sweet rubber smell. Run in well. Tyres are doing well, no uneven wear, I must have hit some pothole somewhere both front and rear right rims bent... had to repair, lucky tires are fine.
Consistent, no complaints and I am gradually pushing them more in the corners.
I think at the price, I will definitely give it 5/5 rating. Don’t compare with PS4 please, if you’re willing to pay ~40% more just buy the PS4.
How does one hit potholes with rim denting impact without realising it? Tummy upset again?
Exactly, I used to use Yoko S-Drives. Friend say PS2 better, I say I know but I don't drive to PS2 max standard, where S-Drive can handle about 80% of PS2 but cost almost half only during that time.......
