go to fstrader's workshop la......
mana tau can get cheaper...
You may go to kepong, behind the maybank. There was a shop which doing adjustable repair. They can repair major type of adjustable. The price is reasonable with good wormanship. I sent there last 2 years, and now still good as usual.
can give location?
may i know the price?
im facing the same problem too....front left side, sound appears when braking only.
cos im afraid the myvi & viva spring rebound is different
hence if the rear is raised abit, the spring could jump from its orignal position,
the only way is to keep it low...your only got hilo only no soft hard rite?
try to set back to low 1st bro..c got noise anot....if yes, then could be the spring rate...
u need to find longer ones though.
Your car lowered very low? What car do you drive? Did you change the drive shafts, ARB link, bump stops etc to match the lowered height?dear car enthusiasts, need some explanation,
i drove out my car from car park which was a steep slope, even i tried to escape thru sideways, still i wrecked my front bumper causing maximum pressure on my front left tire and suspension, now i hear a squeeze sound (front left side) everytime i go over a speed bump,
can someone tell me what could be the reason?
hope u guys can help me, thanks
GAB HE SERIES
