Buying a Bmw 330e
have asked Mr Lee regarding complete 1jz auto conversion
2017 - RM16k
2018 - RM18k
2019 - RM21k....
cant afford to convert la like this.....if manual tranny add another 6-7k.
Ah, Puchong/OKR Lee, his work is legendary. Good stuff. But there are other guys you can go to as well. Pls let me know if you interested. But the main cost is usually the engine. Source the engine and GB yourself, buy the mounts yourself and I'll bring you to my mech who has done several conversions. Might be slightly cheaper assuming you don't go nuts with the mods. Oh and I highly recommend a Links Extreme ECU or something. Don't use piggybacks and complicated setups.
But since yours is a e46, work out that rear chassis crack issue first.
Never had an issue with rear chassis crack ? What are the symptoms ?
It's inherently a problem with all the e46s. Have a read :
http://cmpautoengineering.com/part-1-will-my-e46-subframe-crack-how-will-i-know/
There are a lot of ready made repair kits out there.
Just immediately asked my tuner to check below as i am performing FICD and radiator mod, no cracks and everything is tight as virgin.
If not doing track or driving roughly in plantations, I dont think yours will crack that easily. Btw, no need check. If cracked, you can hear it
Of course those R32, s2000, A86 are not Evos, Evos are boring *yawn* cars, Ironically I happen to Own an Evo8MR running on Tomei turbo+ link ECU. So believe me i am more than qualify to comment on Evos. and I know RM per HP cost. :biggrin:
I own 3 out of the 4 cars u mentioned..
