owner
question is, legally approved or not?owner
owner
Mitsu 2.0 to a mitsu 2.0 engine shouldn't be hard to approve la.question is, legally approved or not?
I think he mean the mod itself, since 4G don't fit proper in 4B space.......Mitsu 2.0 to a mitsu 2.0 engine shouldn't be hard to approve la.
as we all know jpj and custom mounts dont always go hand in hand.... if u tengok betul this guy has messed with part of the frame, crashbar and i think the top rad mount. imo not a super big red flag but something i'm not a huge fan of doingMitsu 2.0 to a mitsu 2.0 engine shouldn't be hard to approve la.
You obviously weren't clear enoughmemang dah beritau pon @_@
There's an easier way to do all this.I am pretty sure lots of fabrication, cutting, welding to the frame had been done to fit the engine, my mechanic friend also confirmed the 4G63 engine mount and gearbox mount is not in the right place to install into 4B engine bay. And the front crash bar is too close to the exhaust manifold of 4G63, need some alternation. Subframe needs some cutting and reinforcing to clear the gearbox and AWD shaft, transfer case mount also different ! Unless all the drivetrain is mechanically constructed, like the older days CD and CE9A, otherwise the later AWD will not work properly on 4B chassis.
I know a creative guy who basically chopped away his entire Satria engine bay + firewall and fitted a evo one in (pretty creative + clean welding) so the Evo bits and bobs were literally plug and play in his car. Somehow managed to pass puspakom and JPJ too without any undertable nonsense. I think he just went to the most slack puspakom outlet he knew to get it cleared. I dunno.
if u can sort of line it up... can wan.. rest is puttyThat welding guy must have superb welding skills that make it look like factory weld !
The welder has quit the industry. Too old already he said.That welding guy must have superb welding skills that make it look like factory weld !
No putty. All pure weld, grind, base coat and paint. Just need to know how to hide the stitches.what...... kerja orang gila ni
Satria engine bay not same as Wira? My ex colleague did VR4 in Satria before, no problem as before the 2.0L problem.....There's an easier way to do all this.
Just too troublesome. Indonesian will say "cari penyakit saja!" Later got some wiring issue, car got burnt to ashes like that one Evo 8 otw to Malacca.
