I wouldn't put it as ripping people off - there is actual science behind their formulation and all otherwise Shell would've been sued by someone ages ago kinda like how Castrol was sued for their Magnatec range.Nothing new that we don't know yet. The statements that older cars not good to use the cheap Shell, and those newer from 2013 better use the Shell Malaysia stuff are just bollocks! Also if follow whatever the mechanics here say then you'll just always end up using the Shell Malaysia one because workshops here are also taking from Shell Malaysia distribution and they will just keep saying the Giant/Tesco ones are fakes, which is BS too.
In summary, the prices from supermarkets proves that local oil distributors like Shell Malaysia and others are ripping off people with ridiculous prices!
There are reasons why older cars vs newer cars can't really go with the same oils. Even Penrite has their "classic car" range of oils that are more suited for classic cars vs their newer HPR / Enviro range of oils. I cannot recall the reason but you probably can research it yourself (www.penriteoil.com.au/products/brands/classic)
If you do a quick google : https://www.autoblog.com/2015/11/18/what-are-the-risks-of-switching-to-synthetic-oil-in-older-cars/
There are reasons la.. it's not to say bullocks altogether.
Yah, especially since it is still group 3 oil, hydro cracked from crude oil.
Actually there's nothing wrong with group 3/4 oils. Most brands run group 3 or 4 except their racing or top end ranges that use Ester base oils. Then there's also the different qualities of group 3/4 oils. Have a read here :
Knowledge Centre | Penrite Oil
All oils are made up of base oils and additives. Not all base oils are created equally however. The API classifies these into 5 main groups. Group III and IV base oils are 100% synthetic. Some very high quality Group II oils (called Group II Plus) are also accepted as having synthetic like...
Don't get caught up too much in group 3 / 4 / 5 base oils. Most modern reputable oils these days are more than well blended with the good stuff. The only things we need to focus on is the additives and how it works / reacts with our cars.
I mean you should know - you use a diesel oil in your car. Kaokao detergents in your oils
