Hi Folks,
After 2 years of running my E46ci with unoptimized 1JZGTE VVTI, i picked up an Edamage Blue which i had for several years to hook it up. As expected, used ECU always had problems, my ignition harness is not readable but the rest of it works fine. Initial runs started with 235 whp/ 315nm wtq at 5.2k RPM. A few more runs and we achieved 251 whp / 320 nm wtq at 5.1k RPM. I am not sure whether this is a healthy result of 1JZGTE VVTI, considering factory declared crank HP is at 276hp which i knew its underrated. Everything is stock except for intercooler pipes, air filter pipe, downpipe and exhaust.
It does drive much better and responsive than before, turbo spool much better and does not consume so much fuel i think. Still experimenting.
Next i will need to fix up the ignition timing on the ECU, get aftermarket FPR, boost controller, and increase the turbo to 1 bar. We should be seeing at 270 whp after that.
Cheers,
Ken
Cheers,
Ken
