The 24 bolts would have been a clueI watched the same video too.
Guess what...the valve cover is holding the camshaft too.
well, first time for me doing 'major' thing on a european engine. felt humbling...The 24 bolts would have been a clue![]()
the cam gears are tensioned, and the valve springs should push the cams off abit... should it not?tbh, so long as the camshaft didnt fully lift up. I think you could have completed the job. It's being held down by the timing mechanism, isnt it?
I dont know..tried again this afternoon and gave up. manage to reinstall the valve cover back. will finish installation tomorrow.tbh, so long as the camshaft didnt fully lift up. I think you could have completed the job. It's being held down by the timing mechanism, isnt it?
yup, no wonder most mech dont want to operate on this engine.What a ridiculous engine design.
If you look at video, the head is really low in heightWhat a ridiculous engine design.
Tbh, I dont really understand why they need to route intake above rocker cover. Can route it at the side like other engine designsyup, no wonder most mech dont want to operate on this engine.
Other than that, its as reliable as any other engine. This engine has never failed me, the electronis is a different story.
BTW, some Nissan also comes with such engine design thanks to their 'love affair' with Renault.
maybe they want a compact design. Normal intake takes about 15cm - 20cm length in the engine bay. By running the intake above the engine, they can eliminate the space. However as we can see, it makes maintenance harder.Tbh, I dont really understand why they need to route intake above rocker cover. Can route it at the side like other engine designs
Ya, like that stupid Livina engine.yup, no wonder most mech dont want to operate on this engine.
I heard Sylphy also.......lolYa, like that stupid Livina engine.
Guys,
I just finish DIY replace the arb link and tie rod on my BLM.
When cleaning up i noticed something that strongly suggest i might have f**k up the simple fix.
The tie rod, some car comes with tie rod which have curve in it while some are just a straight piece.
BLM one have curve.When replacing the the tie rod i just removed and re install according to how the original piece ( on the car since i bought the car brand new )is installed. In the BLM case, the curve is facing the rear of the car. After installation is completed and while cleaning up i noticed there is an 'L' and 'R' sign on the tie rod plastic packaging ( i bought one pair and its packed individually ). If i were to follow the L and R based on the marking on the plastic bag then i have installed it terbalik which is opposite the original installation from the factory.
So, did i f**k up or its ok?
Deep down inside i pray very hard its correct as working at night with bad lighting and not having a hydraulic jack is very stressful....
You should probably redo it. I dont think they purposely make Left or Right without good reason. Something should be in the wayGuys,
Hi guys,
This sad story is no related to the Kenari. That is a customer car came in for a simple suspension and mounting job.
This story focussed on the wicked angle valve on the bench.
This is a major f** up from me caused by a simple DIY job and neglecting a RM70 part.
Most of you knows i own a 1.8 Waja and last month i DIY replace the power steering sensor/switch as its leaking fluid and drips onto the serpentine belt. Sensor is cheap at below RM100. After changing it, i decided to not replace the serpentine belt yet even thought PS fluid had drips on it. The reason i did not replace it is to see if the new sensor leak. If it doesnt then i will replace it....at least thats what is planned.
After a week and while my brother was driving it...this is what he said thru the phone "kereta ko mati, tak bleh start balik. bila try start bunyik kosong". Towed the car to my preferred shop and did visual inspection but see that the timing belt is still in good shape. After dismantling only that the mech discovered that the serpentine belt disintegrate ( 2 rows of it ) and the pieces made its way to the timing belt pulley at the crank causing the belt to jumped a million tooth. I guess you guys knows the outcome to that. BTW the pic only showed 4/16 bent valve.
Went to check on the car after the mech dismantle the head and thank god we discovered that the piston survive, the head survive, so thus the rod and crank. Trying to make myself feels good i joke with the mech "Ni kalau dah siap macam kereta baru lah kan" but the mech just lough in an evil way.....hahahahaha.
RM70 part caused thousands of RM damage.....Ouch.
