Nissan cefiro air cond control panel
brownbear
Terengganu
nissan-cefiro-ac-ctrl-panel-jpg.394205
lately l had my cefiro air cond control panel burnt due to flat battery (over current). Now the air cond stay on all the time at fan speed 3, unless the engine off, otherwise there is no way to turn it off. l was advised to get the air cond control panel replace. Do you know any place l can get this?
Is not the A/C panel problem. Is the power transistor in the cooling coil.
01) If you did a/c service recently maybe the copper pipe touch the transistor heat sink and that also trigger it to auto start at 3rd speed.
02) You have a faulty power transistor. Get from chop shop is about RM 50 to 80. Get new one (not original) about rm 150
Hi Weikee, TQ for being so helpful, l will do it as your advice and let u know of the out come. Have a nice day o(~_~)o
just got the transistor replaced, is working!!!
thank you for saving my time and $$ to trouble shoot hear and there. Have a nice day!
my aircon become hot air.. need to off on acc suis..
anyone facing this problem b4? is it controller problem?
Nissan Cefiro Excimo year 2000 (2.0)-ABS light up
Hi, everybody.. good day,
My car had the ABS light-up time to time, is not permanent light-up, sometimes it just goes off and sometime back again. l went to workshop, the mechanic scan thru and saying the ABS sensor shorted. Is very costly, but no choice l got it replaced. The following day, the problem still exist, some scenerio. Some of my friends told me, perhap not because of the ABS sensor problem, might due to control board mildfunction. Did any of you facing such problem like mine. Appreciate you can share with me the solution. TQ.
My A32 also facing this problem. Have to play with control panel buttons to have cool air.
Did u solve your issue.
Did u replace the aircon control panel?
This is a very old post. I think is better to get an air con shop to check it out......
