does it need to come in one set for ex. (short shift + linkage) or can we just buy the short shift and use the existing linkage.
Any recommendation that works well with civic EG hatchback. Hope can give suggestion what to look for. Any side effect if changed to short shift.
Thanks in advance for sharing.
definitely the ITR short shifter. betterwise complete with the linkage in an EG.
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
