flushafteruse 2,000 RPM Senior Member Joined Jun 2, 2004 Messages 2,273 Points 3,138 Location fire down below Sep 13, 2006 #21 so it can reduce the manifold temp??
J jlxover Known Member Senior Member Joined Feb 7, 2007 Messages 101 Points 1,516 Feb 26, 2007 #22 JL Ceramic Coating :shades_smile: Sure. It help to reduce the exhaust surface temperature which means reduce engine compartment temperature. cheers.. flushafteruse said: so it can reduce the manifold temp?? Click to expand...
D Doink 3,000 RPM Senior Member Joined Aug 1, 2004 Messages 3,489 Points 3,138 Location House Mar 1, 2007 #23 i think if u use stainless steel pipping it also helps to keep the temp inside the pipe... how much price for creamic coating???
J jlxover Known Member Senior Member Joined Feb 7, 2007 Messages 101 Points 1,516 Mar 1, 2007 #24 ceramic coating :shades_smile: the price is depend on what exhaust manifold that you want to coat... NA or Turbo manifold? cheers.. Doink said: i think if u use stainless steel pipping it also helps to keep the temp inside the pipe... how much price for creamic coating??? Click to expand...
