* Rated output per channel @ 4 Ohm (14.4V): 4 x 50 Watts
* Rated output per channel @ 2 Ohm (14.4V): 4 x 70 Watts
* Rated output per channel bridged @ 4 Ohm (14.4V): 2 x 140 Watts
* Frequency response: 20-20KHz
* THD+ noise @ rated output: * S/N (A weighted): >100dB
* Input Sensitivity: .3V-5V
* Maximum current draw: 23A
* Dimensions (H x W x L) in mm: 38 x 217 x 300
Class A also susah to take care ler, generate alot heat, need to maintain the output. Thinking to cold it down abit.....the shield veli hot....aihh:shcokedcamo:
i tot of changing the meter light which mine originally is green wanna change to red. wat i read from other thread is change led colours for example they use coloured led...
