let do compare
do know megasquirt is around 2+ while the microtech is at 4k for lt10s
microtech features
4 Injector Drivers capable of 4 amp peak hold.
True sequential operation on 4 cylinder and rotary
applications
Run up to 4 high impedance injectors per driver
Tunable in MAP or TPS mode or combination of both.
Main Matrix table has 16x16 load sites
RPM tuning range currently every 500rpm to 9000rpm
Overall Mixture trim +-99%
Fuel Delivery Cont:-
Auxiliary Input correction +-99%
Coolant temp correction
Air temp correction
Accelerator pump amount, sensitivity and Time
compensation
Cranking enrichment correction
After start enrichment correction
Cold Start accelerator pump correction
Hard cut RPM limiter
Soft cut RPM Limiter
Over boost Limiter
Sequential, Group fire and Staged/Group fire modes
microtech features
applications
Air temp correction
compensation
Over boost Limiter
, would like to enquire the cheapest replacement for the stock turbo
