SANYO Rechargeable NiMh Charger/Battery
All Other Stuff
standard AAA batteries r producing 250mAh right..that 900 mAh can use?
Chris, please help me to understand what is the benefit / advantages of higher current (A) in the same voltage for batteries ? wouldnt the resistance diode block all the extra ampere its not required ?
Thanks!
aduhh then who can help explain .... tolong laaaa weiiii geng dunt tell me none of ZtH geng is a battery engineer.... heehee :)
the measurement here is mAH,mili-amp per hour. The higher the number, the longer the battery could hold the charge. meaning it is more durable.
so 1000mAh and 900mAh, 1000 will be more lasting. The voltage will be the same for AAA at 1.2v
