Many Performance Parts For Sale
ducktor
mitsubishi 2.0 diesel gearbox 2wd= rm 1100
nissan fairlady piston 87mm (comes with piston ring/pin/conrod) = rm 650
wira 1.6 rear disc brake = rm 600
cusco adjustable hi/lo for evo 4-6 type of lancer (rear only) = rm 500
mitsubishi 4g67 piston 81mm (comes with piston ring/pin/conrod) = rm 400
mitsubishi 4g67 head = rm 600
mitsubishi evo 1 tdo5h turbo without actuator (comes with manifold) = rm 900
mitsubishi evo 1 complete block with custom paper (only without piston) = rm 1800 (item is in kota kinabalu)
all item are negotiable, for more inquiries or for more information pls call 019 8804183
this is originaly is from a n.a. engine, so it is a high compression piston, if wan to install to a 4g91 engine block i think it needs a little bit of boring job to the engine's linear, if im not mistaken 4g91 piston size is 78.5 mm? if it is then think it should be alright if to bore off 3mm from ur engine's linear but to confirm i suggest tat it's better to ask engineering ppl c they can do or not be4 purchasing, correct me if im wrong
oh ic....thanks for the info bro....
i am actually looking low compression pistons.... :)
anyway thanks for answering my question
free bump for u !
come...come... item still available... all items nego
BestPrice
[/QUOTE]
Pm me the best price
update....... come.. come... good items still available
