Piston Crown Coating
jlxover
:regular_smile:
Ceramic coat the Piston Crown which will insulate the piston against damaging heat transfer, keeping more of the heat generated by combustion, pushing down on the piston for greater power. By retaining minimal heat on the surface of the piston, less heat is transferred to the incoming fuel mixture, leading to reduction in preignition which leads to detonation. The coaings can also allow heat at the surface to move more evenly over the surface reducing hot spots and the coatings reflect heat into the chamber for more even distribution of heat, allowing more efficient combustion of fuel. This allows more of the fuel molecules to be oxidized, which in turn, means less fuel is needed for optimum power. The result is an engine that makes more power, can be run with a leaner air/fuel mix and less initial timing and has less thermal expansion due to a reduction in the heat absorbed.
Reasonal price for great performance...
For more info. please visit http://ceramicocoating.blogspot.com/2007/04/coating-piston.html
Interesting...
What are your charges like???
What is the time frame to get it coated???
Wat Ur Price For Vr 4 Standard Piston?
............... bump ............................
is better you to provide all the forumers the charges rather then a general text only. and it will reduced your job to check your PM as well as from customer site!!!
PM me ur price for 4agze pistons 81mm
also, do u do powder coating for turbo manifold? thanks
CERAMICO Coating Services
:shades_smile:
Please check your pm. thanks.
cheers..............
...................... bump ..........................
...................... bump............................
for 3 piece kelisa pistons... pm me the price and how long will it take you to do the coating?
Pm me the price for coating the pistons of a 4G15P...Tq..
