FS-Full system Sale(JL/Exile/Pphoenix Gold/Pioneer)
ICE -In Car Entertainment
lang
Items for Sale !!
Available :
1) pg xenon X10D2-SPEC
Recommended RMS Power: 450W
Peak Power Handling: 800W
Sensitivity: 80.4 dB
175 oz. magnet
Xe-Drive (only found in Phoenix Gold)
Magnetic regulation flux circuit
Ultra-Low Distortion
2.5" Voice Coil
Oversized Magnet (allows the sub too hit extremely hard and deep without distorting)
Removable Magnet Boot
Mounting Depth: 6 1/2"
xe-Line Advanced suspension found only in Phoenix subs allow extreme durability, and long life
Large Roll Butyl Rubber Surround
Computer optimized dual spiders
Custom-Tooled Spider Spacing Ring with Integrated Terminals
True 40mm (1 1/3") Peak-To-Peak Excursion
XeFLEX Reversible mounting gasket and concealed ring
Injection Molded Grained Polypropylene Cone
8-Piece Injection Molded Polypropylene Dust Cap
Expanded Metal Vent Inlays
Black Powder Coated Cast Aluminum Basket
2 8 mm Blue LEDs
Hex Screw Wire Terminals
2) exile 4ch amp x600.4 – SPEC
http://i20.photobucket.com/albums/b225/lang7773/DSC00021.jpg
Specification:
@4Ohms=75W x 4
@2Ohms=150W x 4
@4Ohms Bridged=300W x 2
Frequency Response:+-1db from 20Hz-20kHz
Input Sensitivity:0.2-8.0v
Signal To Noise Ratio:>110dB
Low Pass Cross Frequency:40Hz-400Hz
High Pass Cross Frequency:20Hz-400Hz
Bass Bost @45hz:0-18dB@45Hz
Speaker Impedance:2-4O
Fuse Size:2x25A
Dimensions(LxHxW):16.25"x11.125"x2.625"
3) jl 2way XR650 -
http://www.be-loud.ro/data/product899.jpg
SPEC
Technical Specification
Sensitivity: 89.5 dB
RMS Power Range : 70 Watts
Frequency response: 48-25000 Hz
Diameter: 6.5 Inch
Features
2-way System
XR650-CSi 6.5" (160 mm) Woofer
1-inch (25 mm) Aluminum Dome Tweeter
Grilles Included
70W Continuous Power Handling
Rec. Amp Power: 25 - 150 Watts
89.5 dB Efficiency @ 1W/1m
FR: 48 Hz - 25 KHz ± 3 dB
Free
PG-line driver
FEATURES
Isolated Mounting Clips
Variable Output Level Control
Peak Level LED Indicator
24kt Gold Plated Input And Output Connectors
Pulse Width Modulated Power Supply
Quick-Connect Power Connector
Made In the USA
SPECIFICATIONS
Frequency Response 15Hz to 20kHz &plus mn1dB
THD 0.02% @ 1kHz IMD 0.02% @ 1kHz
S/N Ratio (A weighted) 110dB
Input Imedance 100K(omega)
Output Imedance 30(omega)
Maximum Input or Output Voltage 8 Volts
Power Source 13.8V DC Negative Ground
Dimensions 5.2" L x 3.0"W x 1.25" H
pls pm ur offer
Can Add on 1.4k to Get Brand New US version Pioneer P880 THE EISA Awards 2007 Best Head Unit
http://www.eisa-awards.org/history/2006-2007/images/mobile/Pioneer_DEH_P88RS.jpg
http://www.eisa-awards.org/images/banner0506.jpg
2 Set Available
All items in PERFECT condition. Only The Free Gift is USED.Pm or call me directly at 0124564708
