- Joined
- Nov 28, 2005
- Messages
- 31
- Points
- 1,506
I have a one big problem here. I'm using Kancil fitted with JB-JL engine 659cc. I've upgrade turbo to L902s (JB-DET). Recently i've install 4pc 240cc injector, Walbro 255l/h, Sard Fuel Regulator, FCD and SAFC 5 button.
Problem 1.
To eliminate speed cut (@140km/h) for kei-car i've install SARD Attack Meter. It's display digital realtime speed and also rpm reading. But after i've install SAFC 5 button, my SARD Attack Meter didn't display rpm reading .. Why ??
When Pink wire(SARD) is connected to red yellow stripe(ECU).. RPM indicator at SARD Attack Meter working but SAFC didn't get signal feed for rpm ? But if i pull out Pink wire(SARD) just left SAFC wire connected to ECU.. SAFC got a rpm signal feed.. but RPM at SARD Attack Meter not displaying any number .. any solution ??
Problem 2.
Why my SARD Fuel Regulator cannot adjust my fuel presure?? Once u start ur engine, the presuregoing up to 3.1bar. Is this thing happen because of my fuel pump walbro ?? or SARD fuel regulator didn't working anymore ?? To drive my car, all my SAFC setting must set to -ve 30, if not .. very rich fuel mix. Any solution ??
Tq..
Problem 1.
Problem 2.
Tq..
. Anyway...
