HanJackaL said:1)How much will it cost to make a Silvia S15 Spec R 350WHP?
I will said it range from Rm 20,000 to 30,000
2)What mods needs to be done ?
I assume your S15 are stock standard, you need
a) Good ECu ( Apexi D-jetto / F-COn-V-Pro),
b) High cam ( valve spring if you want lift higher than 10.5mm)
c) Min 555cc injector,
d) Intercooller
e) Oil cooler
f) Fuel pump, fuel regulator
g) Equal length manifold, exhaust, downpipe
h) 1.5 to 1.8mm metal Gasket
3)Will car be still reliable?
I will said, if you good yourself a good tuner yes, but to answer your below question, I think it is possible to reach this target using stock turbine as I saw a lot of Japs magazine had did it. But I always think this way, if you use the max out of your turbo, changes are you will wear down your turbo easily.So it is realible , is really to me unprove issues but I will say if using stock turbine, nope it is not reliable.(p/s I might be wrong , don't shoot me :mouth_closed: )
4)With stock turbine and intercooler,is it possible to reach my target without sacrificing reliability?
Please help!
Thanks!
Here are my know little pretend experts answer :_:
d) Intercooller
e) Oil cooler
I will said, if you good yourself a good tuner yes, but to answer your below question, I think it is possible to reach this target using stock turbine as I saw a lot of Japs magazine had did it. But I always think this way, if you use the max out of your turbo, changes are you will wear down your turbo easily.So it is realible , is really to me unprove issues but I will say if using stock turbine, nope it is not reliable.(p/s I might be wrong , don't shoot me )
Please help!
Thanks!
damn for 350 hp in malaysian rm i dunno but my 180sx is makin 320rwhp n it cost close to 30k dollars not ringgit.btw i live in australia :) u are lucky to be livin in m'sia as prices are cheap compare to here
my car is capable of 370rwhp but at the moment its only 324rwhp at 1.0bar
Trust TD06 20G turbine
Trust v-spl fmic
Trust 10row oil cooler kit
Trust high mount manifold
Trust 45mm wastegate
Trust 3 piece pulley kit
Trust airynx air filter
Cusco oil catch can
Cusco brake cylinder stopper
HKS ssqv
HKS earth wiring
HKS full exhaust system
HKS engine center piece cover.
HKS heavy duty valve springs.
high flow catalytic convertor
Z32 afm
Bosch 044 fuel pump
TOMEI stageII 264/264 camshaft.
TOMEI 740cc injectors
TOMEI adjustable cam gears
TOMEI 1.2mm head gasket
TOMEI rocker arm stopper
ORC twinplate clutch
C's short shifter
Nismo gearbox mounts
Nismo engine mounts
ARIAS forged pistons
Eagle forged conrods
port & polished head
balanced internals
treated & engineered head & block.
other specs:
Sabelt 3-Point harness
Trust Dual Pod Pillar Mount
Apexi rsm
Apexi power FC with FC commander
Nismo Gear Knob
Nardi Type-A Deep Dish S/wheel
Blitz Full Electronic Turbo Timer
Defi Sport VSD (Head Up Display)
Defi boost
Defi oil temp
Defi water temp
Defi oil pressure
Defi exhaust temp gauges...
Defi control unit
Suspension and Wheels Modifications
Nismo front/rear control arms
Nismo rear upperlink
Cusco front tension rods
Cusco rear castor rods
Cusco front/rear strutbrace
Tein Type HE Coilover
Whiteline pineapples
R32 gts front 4 pot calipers
DBA slotted rotors
KAAZ 1.5way LSD
work meister s1 polished 18 x 8 & x 9.5 on yokohama advan neova ad07
with Origin Lab aggressive one kit
