How to clean to mark?
singchaii
Pandan Jaya, KL
Hi guy.. recently I just removed those custom sticker on my rear windscreen(outside). After remove the stickers, it had mark on the windscreen. I had try to clean it using window soap and car shampoo.. But the mark seem not removable.. How to remove those mark? T
use polish...
if still cannot remove the mark..use thinner
Polish also can?
I had wipe it off and now is visible.. But when pour water, it have the water mark exactly the sticker design there.. can i clear it also?
use zippo lighter fluid or thinner.u can use wd40 too.
try spray soap water n use blade n slide de glass.. it will remove anythin ehehe..
yea..u can use polish..
did u tried using blade to remove all the glue?
or u can try to use claybar..
I wonder why some sticker will have glue on it.. Izit because of low quality? While my some custom made sticker very nice.. When take off, nothing will stick on the windscreen.. Why finally I done all the mark.. I bought a tin of sticker remover at accessories shop.. Spray on the sticker, it will remove in few seconds.. Nothing left on the windscreen. After done it, then use Rain X to wipe the windscreen. Hehe.
how about our locally made road tax? it is pasted inside the windscreen, not outside... sometimes when take out that time very hard, and if take out already, some stickiness will be left..
wat to do? If use thinner, will it affect our tinting film? hmm
spray degreaser on the mark,then use ur finger and rub rub rub, sure come out wan, very efektif :biggrin:
guess its called watermark bro...its daymn expensive to make em go away...go to polish shop/centre and they'll charge u for some $$$
fuys.. i had the same problem.. removed a sticker.. and what happenned after that is i used a sponge to scrub the dirt off.. result..? there are some pretty deep scrathes remaiming.. due to the sponge..
what do you guys suggest.?
how do i make em scrathes go away..?
Yeah, WD40 or Silicon spray absolutely work. Last time, I had a marker pen ink on my windscreen (transfer from car sticker) and I used Silicon spray, all gone. Two days ago also got glue stick on my bumper and I used WD40, also gone. So, you can choose either one to solve urs :-)
Zippo lighter fluid with a soft towel and then any cleaning liquid with newspaper...it worked for me.
guys how bout on body paint?
last time use to stick rear lamp reflectors but i took it off because colour faded over years.. now got those remnants of thick double sided black tape which is hard to remove.. coz its already half tear and it stick on the body... i tried lightly scraping it off with a blunt edge of small wood scrapper with soap but it doesnt come of easily.. and end up some scrathes to the paint due to carelessness :((
any suggestions guys? :bawling::bawling:
U cant use soap, u need a solvent. Try bringing ur ride around if ur near our area and we'll try to remove it for u.
