CTR & ITR fuel pump is the same or not? how about those non-R fuel pump?
dohc vtec ones should be 135lph. by all means itr, ctr, gsr
pressure wise, get it run on a dyno. diff car has diff spec.
why do you need exact numberst? If fuel pressure drops when your injectors are maxed out, your pump is too small (or you have issues with your fuel pump).
As for the exact numbers, I don't know.. I don't think anyone has measured the flow rate.
The reason being, i've bought an aftermarket fuel pump which stated as 220LPH. So i'm wondering is that 2 much 4 a b16a. PLus i'm running on a set of CTR cams n CTR pistons.
Yes, could be 2 big.. but..I think, depending on your final AFR target, it could be too much.
But I've pushed the stock fuel pump to the limits already, out of curiousity.
For 100% duty cycle on stock injectors, I have slight pressure drop at the regulator +/- .3bar, which means with 240cc injectors running 3.5bar at WOT, the stock fuel pump cannot cope already. I did however achieve 10.3-10.6 AFR at those settings. (this actually was my finding when I tried to figure out what causes the afr curve to spike.)
Interesting, eh?
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
