Dear fellow members, please help on this little brake survey for my project. Thank you so much.
Please copy and paste at your reply post and edit from there. Thank you!
You can select more than one.
Survey: Light weight brake disc rotor.
- Will you wish for a light weight disc brakes?
- Yes
- No; Why? __________________________________________________
- Should manufacturers equip their vehicles with light weight disc brakes?
- Yes
- Will you invest your money on light weight disc brakes?
- Yes
- Cross drilled disc brakes are with holes drilled across the disc to vent gasses developed by brake pads and remove water layer during the rain. What do you think about the cross drilled disc brakes?
- Make up purposes
- Gain braking performance
- Slotted disc brakes are with little channels to vent out gasses developed by brake pads and remove water layer during the rain. What do you think about the slotted disc brakes?
- Make up purposes
- What kind of design would you prefer for better braking performance?
- Cross drilled
- Plain
- Slotted
- Both cross drilled and slotted
- Futuristic designs
- Others; Please specify ________________________________________
- What kind of design would you prefer for outlook?
- Cross drilled
- Plain
- Slotted
- What problems you encountered with your disc brakes before?
- Disc warp
- Heavy weight
- Crack
- Insufficient disc and pad grip/friction
- Overheating
- Will you accept high technology future designs rather than the available conventional designs?
- Yes
- No
- What do you expect to gain from a set of light weight disc brakes?
- Better fuel consumption
- Better stopping distance
- Better acceleration
- Reduce in overall weight
- Is the braking system upgrades an important aspect to you?
- Yes
- No
- Will a light weight disc brake be in your future modification list?
- Yes
- No
