GT... try to imagine this.... take an example running 1.5bar with 38mm gate.
lets consider the 38 is small ....and it will spike to 1.8bar.. and i understand you trying to say that boost will only go higher if you use smaller gate.... hence if i presume that your boost that you want is actually 1.8bar, then your gate already start opening at 1.5bar and creep up to the 1.8bar.and that doesnt do any good too for your spool up...
an effective and efficient setup is ... gate fully close...assume you want to boost 1.5bar. it should be fully close untill 1.5bar and when the moment it open it will release all the xtra and hold your boost steady on 1.5bar. this means that your spool up time faster and hold your boost steady without spike. i would recomend to use biggest anyone can afford and play around with the spring and a proper boost controller. no harm having bigger gates. but never undersize a wastegate.
yes i understand ur statement rexun.what i'm trying to say is that small valve
hold hi boost better then the bigger 1.imagine the exhaust escape from the
bigger valve.the small valve will make the exhaust gases squeeze itself out from
a small hole hence higher boost.let say if ur looking at 1.8,of course we want
it to reach the targeted boost before the valve open.that not the issue here.
the issue is that the capability of a smaller valve to hold the boost higher
then the bigger valve.1 example is like today.i talk to a friend of mine who
own a 5++ hp drag satria.he's selling his 38mm tial w/gate n getting a bigger
1.i ask him why n he said that he's aiming for a lower boost at launch cos
the smaller valve tend to give higher boost.even tial n turbosmart recommend
this kind of set up.
"The more powerful the engine, the bigger the wastegate you need. This is one of the more popular misconceptions. Use this simple guide before setting out to find the biggest wastegate you can afford.
Big Turbo/Low Boost = Bigger Wastegate
Big Turbo/High Boost = Smaller Wastegate
Small Turbo/High Boost = Smaller Wastegate
Small Turbo/Low Boost = Bigger Wastegate"
-quote by turbosmart company.
or maybe this site can explain it better then me.:)
http://www.evans-tuning.com/tech11.html
and this site.
http://forums.performancecar.co.nz/phpBB/viewtopic.php?p=455903&sid=a901ed4ecca264afc5501659531eb0fa
btw,"it should be fully close untill 1.5bar and when the moment it open it will release all the xtra and hold your boost steady on 1.5bar"-this only work if u
have gated or electronic boost ctrl.it will hold the boost n let it go once the
targeted boost is reach.
