(WTS)-JVC KD-G335 Mp3/wma player for sale
ICE -In Car Entertainment
putera7
The unit is compatible with MP3 and WMA format on CD-R/RW discs, with ID3/WMA tag display. Enjoy your music in high resolution with 24-bit DAC, in 50W x 4 power output. The 3-band iEQ and SuperBass lets you customize the sound to your taste. Other features include rotary encoder and wireless remote control.
Highlights
• Power Output: 50W x 4 Max.
MOS-FET Power Amp
• 24-bit DAC
• 3-Band iEQ
• Line Output Terminal with Rear/Subwoofer Output Switchable
• Subwoofer Level/Frequency Control
MP3/WMA Compatible with ID3 Tag/WMA Tag : Yes
CD-R/RW Compatible : Yes
CD Text : Yes
Direct Track Access (1-12) : Yes
Random/Repeat Play : Yes
Frequency Response : 5 -20,000 Hz
Dynamic Range : 96dB
Signal-to-Noise Ratio : 98dB
Channel Separation : > 85dB
Wow & Flutter : less than measureable limit
Amplifier KD-G335
Maximum Power Output : 200W (50W x 4)
Continuous Power Output (RMS) : 4CH: 20 watts per channel into 4 ohms, 40Hz - 20kHz, at no more than 1.0% total harmonic distortion
MOS-FET Power Amp : Yes
Audio DAC
24-bit DAC : Yes
Volume Attenuator : Yes
Super Bass Control : Yes (5 step)
Bass/Treble Control : Yes
Balance/Fader Control : Yes
EQ
3-Band iEQ : Yes
Max. Amp Gain Switcher : Yes
Line Output Terminals (Pair) : 1 (Rear) (Switchable)
Subwoofer Output with Level/Frequency Control : Yes (Switchable)
Frequency Response : 40 - 20,000Hz
Load Impedance : 4 ohms ( 4 - 8 ohms allowable)
Switchable Dimmer : Yes (Manual)
Detachable Control Panel with Carrying Case : Yes
Item is in good condition and still under warranty
Reason for sale: upgrade
Price : RM270 (Neg)
Can sms or call : 0172963703
tq
Highlights
MOS-FET Power Amp
• 24-bit DAC
• 3-Band iEQ
CD Text : Yes
Amplifier KD-G335
Audio DAC
24-bit DAC : Yes
EQ
3-Band iEQ : Yes
Line Output Level : 2.5V
Line Output Impedance : 1k ohms
Subwoofer Output Level : 2.5V
Reason for sale: upgrade different model
Price : RM300 (Neg)
Can sms or call : 0123302577
tq
price updated..tq
