3S-FE,GE,GTE Discussion/Gathering
eyong-
good to hear that ~! and those turbos are awesome but it's for 185 only. mine its now 245 or rather 205 series... hehee
ToyoRism-
What's sort of performance parts you got there?
share with us then
Cheers
eyong-
The second turbo came out for ex-works WRC corolla and basically they uses the ST205 engine, minus the water-to-air intercooler. Did you heard "Magnesium" housing? Woooooo ..............
eyong-
wooh.. that's cool stuff, no wonder can boost till 2.8 bar. impressive!
runs on 205 engine ~ just my cup of coffee!!! lolxz
mg housing?! interesting... ^^ GT4ALL... should get it...
where is my sifu?! gone missing?!
202R... yes... im free... r u coming to GT4ALL w/s?!
Mg housing are purpose made for race teams only .... You won't get it from Turbo Tong nor any Garrett dealer ... Now, that's the LCLY part of it. Hahahahaha.
eyong-
lolz... but it's cost 2gm usd though... costly~~~
KNZ2k1-
not following just going along only.
eyong-
Yeah, that would be the downside of things ... But hey, it's Mg, it's TTE stuff and it had been proven to win championship just like the ST-185. Correct?
I want those babies too .... Unfortunately I needed 2 of them now, uuuurrgh ... :mad:
202R...
so... thursday... plan?!
Yup, tomorrow I'll reach KL at around 12 noon. As I don't know the way around KL, my friend or the seller will be waiting for me somewhere at the Jalan Duta roundabout. I'll call you then or when I'm about to reach there. I think GT4 will also be tagging along. Hehe.
Guys,
Is there anyone using the 3S-GTE here with a FF gearbox ? I mean not MR2 gearbox; I'm asking about non MR2 gearbox.
If so, what gearbox are you guys using, I mean from which model ?
2. What clutch plate ? Hi-lux ?
3. What size, 8.5" or 9" clutch plate ?
4. Can the the 4WD gearbox internals be tranfered over to the FF gearbox housing & used as 2WD FF ?
Any help will much appreciated. Thank you.:adore:
eyong-
how i wish my engine it's not dead at the first place... would save enough money to get those babies~~!!! better then boobs ! lolz
1. What FW gearbox to use
- Camry either 2.0 or 2.2, GE, FE or corona gearbox will do.
- 3S-GTE or exedy
- Preferred 9"
- Yes, sir. it's the same but the gear ratio only. <<<=== correction it's the other way around, trow away 3S-GTE 4WD gear ratio but use only the housing. sorry bro, abit blur when replying your message...
eyong-
Apa jadi ni? Engine die liao wor??? But don't worry, got a purpose built, bullet-proofed 3S-GTE engine with Autronic anti-lag, but but but ... you got to go down south to fetch it though *sign*
Hilux clutch???? I just can't help but smirk ... sorry, hahahaha ... Go Ogura (ORC) lor ... worth it in the longer run coz it's a bitch to replace 3S-GTE clutch lor ...
Gbox issue...
Supercharge also can but internal mod must be done.
im using 3sge gbox corona... but cluth plate cannot used ori 3sgte one.
must to mod da middle hole 21 teeth. although cannot match into 3sge gbox.
ive seen Ae111 wif 3sgte 4wd gbox from kuching.. dunno how they made it.
im looking to replace my cluth plate also..
eyong-
good one - Ogura (ORC) or else OS Zigen lolz
well, it was certified on the HPC track day 1 month ago. she's just discharged from workshop... with 245 engine, good condition but lots of stuff cannot re-used.... sign.... anyhow, she's back now and still under monitoring.
Harris3s-
you got that right bro. the most important thing its the center mouth, its either big or small. 3S-GTE is bigger but corona it's smaller. once sorted out this issue, what clutch plate also can use.
eyong-
Sorry for being a lame arse, but what's a 245 engine :confused: :confused: :confused:
