that depends on what car. from what i know, if proton wira/satria then yes.
1.3 and 1.5 share the same abs and spring while 1.5 and 1.6 share the same as well.
please don`t mess up...yes 4g13 and 4g15 share the same suspension..
but 4g15 and 4g92 (1.6) can`t share together beco the 1.6 engine is heavy in load...so once put in 1.5 the car will look front alot higher...
BUt previous on Wira SE special edition they is few spec loaded with 1.6 spring and absorber from waja....but both been retune and readjust only put in...( you can get this special spec from EOn, mutiara proton or glenmerie.....ask for WIra SE spec suspension... is totally reprofile suspension..
normaly 1.3 and 1.5 spring diameter is smaller then 1.6 srping diameter.. so again...is not same
