[WTS] Denso Iridium Power Racing Spark Plug (at its lowest price)
Cola
Selangor
AVAILABLE PLUGS AT UNBELIEVABLE PRICE:
Retail price: RM210
RM170 one set (4 plugs)
IK20
IK22
IK24
Contact: Larry 012-6527100 to arrange for deal.
Courier service shipping: 1-2 days time arrive
Installation can be arranged at minimum charges.
Buy now, 1 box of 4 plugs at only RM170 (SAVE RM40)
To view the chart of compatible car list
Ignitability That's a Cut Above
Get more power with an optimal combustion cycle.
Increased response and acceleration performance.
IRIDIUM POWER best demonstrates its performance improvement during acceleration.IRIDIUM POWER has a 0.4 mm diameter iridium center electrode and a specially shaped ground electrode. These features combine to achieve higher ignitability and require lower spark voltage than ever before. This enables high-response driving with fewer misfires than under higher required voltage spark conditions, and fewer misfires when ignitability is difficult. As a result, acceleration improves in comparison with normal plugs.
The 0.4mm center electrode increases output under various driving conditions.
The power produced by the 0.4mm dia. iridium center electrode is IRIDIUM POWER unmatched by other plugs. The graph below compares the resulting power when IRIDIUM POWER is installed compared to other high performance plugs. Using a 0.4mm dia. fine center electrode, there is more power compared to 0.8mm and 2.5mm dia. plugs. This is what makes the difference in acceleration and in your lap time.
Even during idling ignition is assured, with less fuel consumption and less noise
The good ignitability from the fine electrode (0.4mm) of IRIDIUM POWER draws out much more performance from the engine. Comparing a normal plug (W20FS-U) with an IRIDIUM POWER(IWF22) on a 2 cycle 50cc engine, fuel consumption improved from 41.74km/L -> 43.69km/L, an improvement of about 5%.
Note: Mileage measured using a chassis dynamo; actual driving results under normal conditions may vary.
The Secret behind DENSO's Iridium Patent!
Plug electrodes conventionally have used nickel and platinum. These were not pure metals, but alloys containing other metals. Depending on the composition of the alloy, the matrix material's properties can be maximized. Using the same approach, iridium is alloyed with rhodium. The rhodium layer covers the iridium, improving the properties of the iridium. This iridium/rhodium technology was recognized by the Patent Offices of Japan and the UK, and in January 1999, a patent was granted in each respective country. (Patent Number - Japan: 2877035, UK: 2302367). Because DENSO had this patented technology, DENSO was able to make dia. of the iridium down to 0.4mm.
The most important things for plug performance are ignitability and sparkability. To make the electrode as fine as possible is the goal of spark plug manufacturers worldwide, and DENSO has taken the lead, succeeding the commercializing the 0.4mm dia. center electrode plug.
The finer the electrode, the more concentrated the electrical potential and the stronger the electrical field strength becomes, leading to a lower required voltage. This results in a steady combustion in a variety of driving conditions, and better starting and acceleration for the engine.
A Pattern from Spark to Ignition
Electrodes have a quenching (cooling) affect (where the heat of the ignited flame kernel is taken away by the electrode). This cooling affect is greater with larger electrodes, sometimes causing the ignition to stop short of the stage in Figure 4. To improve ignitability, the contact area between the electrode and the flame kernel must be reduced. Improved ignitability is why IRIDIUM POWER electrodes have been made fine as possible.
bro got for toyota celica 3sGTE engines?..PM me best price
bro, kenari suitable which type???? pls offer me ... thanks!!!
KENARI 1.0 98.~ D680 EJ-DE K16PR-U11
DENSO IK16
Call to make order now, 012-6527100
for IK16 got?
my car is kelisa and it uses only 3 plugs..
is it possible to buy only 3? or must buy 4?
bro..for mira l2s with oversize piston and kenari gearbox which plug is better?want performance plug?suggest me?
to see which plug is suitable, kindly check at the chart in denso website
I only have Denso model IK20 / IK22 and IK24 for offer.
http://www.denso.com.my/apply_sparkplugs.htm
