Hi brothers and sisters,
I am thinking of removing my leaking power steering components and build my muscles. Ford Laser KH 4 door sedan with standard B8 180 engine.
http://www.tx3nz.com/img/picsbymodel/kh.jpg
This is just an example from the net.
1) The problem is, one belt is pulling the air conditioner compressor with the power steering pump. What should i do? Measure and get a shorter belt? Can the belt be tensioned without the power steering pump?
2) The removal means reroute both pipe ends at rack together again with fluid inside? Will it be possible my rack is leaking? I am afraid end up drying my rack.
3) Is there any manual rack available? This would be my last option as it involves current rack removal.
Thank you so much in advance. I spend RM25 (1 liter) per bottle of power steering fluid a month to top up the leaking system.
