redline 10w-30 work best with hi revving n/a engine.it makes ur engine lighter
cos of the thin viscosity.
wah.....sifo....how much ar per bottle???hehehe......
how about for turbo engine bro?
for Coke is rm1.20per can & rm1.60per bottle....
how many liter...?? i dunno..ahahaha...![]()
waaa.....cannot afford it leh.....to damn cheap...hahaha![]()
at least *w40.not recommended below 40 for turbo.
so Redline 10w40 can be use?
how bout if not losing compression, still need to seal it..??
sorry, newbie here...
if not losing compression? den u can use a lower weight oil
compression is supposed to be sealed in the combustion chamber by the compression piston rings, but if the rings cant hold it in then a thicker oil mite help to reduce the losses by filling in the gaps between the cylinder wall and the rings. oil is actually used to lubricate, to reduce friction on moving parts, not to seal compression in. but if we can use it for another reason just by changing to a heavier weight, then y not?
, 2 kuk kong
, 3 kuk kong
.....sifooooOOO!!!
Anyone have a good all-in-one centre to recommend?
